****wants to turn over fine but wont start check this out****
Old Apr 13, 2006 | 08:51 PM
greddy13's Avatar
Default ****wants to turn over fine but wont start check this out****
ok so my car would start fine but i needed to change the TB but the new one needed all the lil pieaces like the spring and all that crap...i so changed it all over and installed it and went to start the car. it would start but when u put the peddal to the floor it would accelerate very slowly and the engine would shake bad etc. so i took the TB back off then put it back on and it wouldnt start at all....i jus loooked at my distributor and the inside is loose but is tighten as tight as possibe..i looked at the 2 plugs where u plug the diss. in with the harness and the round one has a tooth missin...but it started up fine like that. everything works...has fuel, fuel pump works, all the vacumes are hooked up corectly nothing looks wrong with it. so does enybody here have eny ideas i could try.
Old Apr 14, 2006 | 10:18 AM
greddy13's Avatar
Default Re: ****wants to turn over fine but wont start check this out**** (greddy13)
bumpppppp
Old Apr 15, 2006 | 12:04 AM
thahuhstunna's Avatar
tough to follow your description,but from what i'm getting it really sounds like the distributor... i'd also try and find a new throttle body,but it should run fine with what you have
gl
Old Apr 15, 2006 | 05:08 AM
greddy13's Avatar
Default Re: ****wants to turn over fine but wont start check this out**** (thahuhstunna)
yea thats what i was thinkin...im goin to put a diffrent distributor on
Old Apr 15, 2006 | 12:21 PM
greddy13's Avatar
ok i put a diffent one on and thats not the problem you all no jus as much as i do...all i did was put a diffrent throttle body on switched all the stuff over like the spring etc. and it started and accelerated very slowly and shook bad then tried to start it again and it wouldnt start....so i put the old one back on and it still wont start.
Old Apr 15, 2006 | 03:11 PM
Ryan C's Avatar
firing order?
Old Apr 15, 2006 | 03:31 PM
greddy13's Avatar
Default Re: ****wants to turn over fine but wont start check this out**** (Ryan C)
what do u mean, the plugs are on right
Old Apr 15, 2006 | 03:32 PM
Ryan C's Avatar
its worth double checkin, this sounds like it
Old Apr 15, 2006 | 06:31 PM
greddy13's Avatar
yea there on right 2-1 4-3
Old Apr 15, 2006 | 08:44 PM
Ryan C's Avatar
why did you have to replace you tb in the first place?
also, have you checked to see if you have the map and tps plugs switched?
i bet thats what it is
Old Apr 15, 2006 | 10:41 PM
greddy13's Avatar
the map and tps plugs switched? what do u mean...everything pluged right up...and i had to change it b/c one of the vacume lines u plug in the "nipple" was broken off so it wouldnt go on...and without it it would idle and smoke badly.....but what do u mean change the tps and map plugs? i have the old TB on but fixed the "nipple" so it plugs in...it still wont start im not useing the one it came with so it should work..still nothing
Old Apr 16, 2006 | 06:55 AM
Ryan C's Avatar
the map and tps are both on the tb and they will both pkug into each other. i garuntee thats what you did.
just switch the map and tps plugs
Old Apr 16, 2006 | 08:43 AM
greddy13's Avatar
i have no idea what they look like
Old Apr 16, 2006 | 12:14 PM
greddy13's Avatar
its obd0....it only has one plug and its plugged in
Old Apr 16, 2006 | 08:11 PM
greddy13's Avatar
simply all i did was take off the throttle body got a new one. swaped all the stuff like the spring and the throttle disc thing. and the other thign with the 2 screws and installed it and it stared but shook very bad and wouldnt accelerate fast. so i took it off messed with it put it back on and it wont start at all....so i put the old one back one...hooked everything up and still wont start...this is unbeleavable...i need to get this started asap...
Old Apr 16, 2006 | 08:53 PM
greddy13's Avatar
enymore ideas????
Old Apr 17, 2006 | 08:26 AM
Ryan C's Avatar
how about a mechanic
Old Apr 17, 2006 | 09:15 AM
greddy13's Avatar
yea, im tryin to get my buddy to come down today
Old Apr 17, 2006 | 09:41 PM
lito1208's Avatar
I used to have that problem when it start slowly even when the paddle is down to the floor and shaked alot. check your timing and the idle screw on the TB. also if you got the plug switch from the map and tps it will idle funky.
Old Apr 20, 2006 | 06:59 PM
greddy13's Avatar
Default Re: (lito1208)
its obd0 and theres only the tps on the TB....the tps isnt the problem cause i put my old tb back on and it still wont start...
Old Apr 22, 2006 | 08:01 PM
greddy13's Avatar
Default Re: (greddy13)
FOND OUT WHATS WRONG WITH IT! ok so i had my buddy come over and he checked my timing belt..it jumped a tooth...then he told me the distributor wasnt eny good...so i put my buddys dizzy on and it STILL wouldnt start...so we took out the spark plugs and thats what it was...i got to the 3rd one and turns out it was cross threaded and wasnt commin out and ended up brakin in half in the head...so i now i gotta put my spair head on get a new distributor new head gasket and who knows what else...hopefully it'll start then....
Old May 5, 2006 | 12:33 AM
good luck to you
bart simpson
15
Apr 6, 2010 12:21 PM
devin_hoang
11
Dec 31, 2008 06:01 PM
bmxbikes
22
Jul 4, 2007 07:23 PM
boostedpleasure
13
Oct 12, 2006 09:10 AM
vtecn8ive
21
Nov 5, 2005 09:35 AM
