mini me???? what head is better
Old Apr 13, 2006 | 08:38 PM
jdmcivicsi522's Avatar
Default mini me???? what head is better
i have a d16y7 in my car and would like to do a mini me swap should i use the y8 head or z6 head i am also turbing so which one would lower my compression what all do i need to do this swap??? i need help asap and i have and d15b vtec head would that be my best bet or what thanks
Old Apr 13, 2006 | 08:43 PM
crxnj's Avatar
Default Re: mini me???? what head is better (jdmcivicsi522)
A d15b vtec head is the same as the d16z6 head except for the camshaft..Z6 head would yeild a lower compression ratio,,but the y8 manifold is great for turbo..
Old Apr 14, 2006 | 08:12 AM
Default Re: mini me???? what head is better (Mr.speaker)
couldnt i swap manifolds and to complete the swap would i keed different wiring harness and sommeone said i could splice wires to make vtec work and keep the same harness
Old Apr 14, 2006 | 04:41 PM
crxnj's Avatar
Yeah ,you can use the y8 manifold on the Z6 head..
And you add the wires for vtec ,,then pin them into the ecu clips and use an ecu that can control vtec....Dont just put the head on and run the vtec wire to an rpm switch,,thats not really vtec,,you also need the fuel and timing that goes along with it..
Old Apr 14, 2006 | 06:05 PM
ok thanks alot does anyone know where i can get decent valves
GhostRidaz
Dec 24, 2010 01:47 PM
Cras-Delsol
15
Sep 19, 2008 09:39 PM
90efSI
Northwest (Sales)
Oct 9, 2005 01:43 PM
honcrx91si
May 5, 2004 06:13 PM
Layziebtnh055
Apr 29, 2004 01:44 PM
