FS: D16z6, LS/Vtec, YS1, Skunk2, RSR, AEM, etc. Good stuff!
Old Apr 13, 2006 | 08:01 PM
Twinkies's Avatar
Default FS: LS/Vtec, YS1, Skunk2, RSR, AEM, etc. Good B series stuff!
LS/Vtec engine. B18a1 block PR3 head. Ls crank and rods. ITR oil pump. ITR pistons. CTR cams. AEM old style blue cam gears. Earls fittings. NGK spark plugs. Built by Jay (Speed Machine of Escondido, CA. Business owned by Matt formerly of MMR. The same guys on the TV show "Pinks." ) Runs STRONG for an OEM setup. Its seen nothing but OEM filters and Castrol Syntec in its 10k since build.
Seals, bearings, water pump, timing belt new at time of build.
All cylinders checked at 210psi before engine was removed from car.
$1600 bare engine, great deal.
OBD0 B16 distributor with fairly new (10k) OEM spark plug wires... $100/obo
cable B series starter. $best offer
ACT extreme pressure plate with full face disc, very good condition at last inspection. Its definitely not a cheap setup, definately has some life left. Stiff pedal for the So-Cal stop and go driving, just so you know. Cable trans. $best offer
Factory 1st gen B16 fuel injectors. $best offer
Skunk2 B16 intake manifold. Tapped for nitrous nozzles on top side of manifold to clear fuel rail. Comes sealed with plugs since you probably aren’t running nitrous.
Includes air temp sensor and EACV.
$140/obo
Crower 402 cams. Dont ask why, but they sat outside for a while and have surface rust. Should be salvagable with machining. Email for pics.
$best offer
Factory gen1 B16 cams and sprockets. $best offer\
Porsche heavy duty battery cut off switches. Mfg by Hella. $10 each.
I have a few available.
Pictures, block numbers, etc available upon request... Im legit.
Riverside or San Diego pickup.
email is best... twinkies81@hotmail.com
Modified by Twinkies at 3:02 PM 5/7/2006
Modified by Twinkies at 3:05 PM 8/29/2006
Old Apr 15, 2006 | 07:53 AM
Twinkies's Avatar
Default Re: FS: D16z6, LS/Vtec, YS1, Skunk2, RSR, AEM, etc. Good stuff! (Twinkies)
Old Apr 17, 2006 | 06:58 AM
Twinkies's Avatar
bump
Old Apr 18, 2006 | 06:55 PM
lcjarrett's Avatar
Bump for the VAFC...if I hadad cash I would buy it.
Old Apr 25, 2006 | 07:03 AM
Twinkies's Avatar
Default Re: (lcjarrett)
Old May 7, 2006 | 02:02 PM
Twinkies's Avatar
Default Re: (Twinkies)
Old Jul 3, 2006 | 10:44 PM
Cheeech's Avatar
pm'd
Old Aug 29, 2006 | 12:46 AM
L5th's Avatar
Default Re: FS: LS/Vtec, YS1, Skunk2, RSR, AEM, etc. Good B series stuff! (Twinkies)
interested
96redEKhatch
34
May 6, 2010 07:09 PM
insidiouseg-6
Feb 4, 2009 08:51 PM
boosted dc4
10
Jun 6, 2006 10:10 PM
hondaballs
Jan 31, 2005 03:16 AM
gookspeed
Jan 2, 2005 10:07 PM
