brakes..... very spongy cuase?
Old Apr 13, 2006 | 06:21 PM
SloA$$ DA's Avatar
Default brakes..... very spongy cuase?
recently changed my brake master cylinder. but my brakes still feel very spongy, any ideas on what it could be? and i bled the brakes already do you guys think i should bleed them again?
an is there any way to adjust the gas pedal to go a little further down.... its really high and its extremely hard to heel toe.
Old Apr 13, 2006 | 06:34 PM
Mavrick's Avatar
Default Re: brakes..... very spongy cuase? (SloA$$ DA)
unless the master cylinder is malfunctioning it definately an air problem. What procedure did you do?
Old Apr 13, 2006 | 06:58 PM
SloA$$ DA's Avatar
Default Re: brakes..... very spongy cuase? (Mavrick)
procedure? as in pumping the brakes? had some one pump and hold while i bled. went from rear passenger to rear driver to front passenger to front driver. maybe i just need to re bleed again... ugh... so messy.
Old Apr 13, 2006 | 07:01 PM
8atman's Avatar
i just did the same thing, sounds like your m.c. might be bad, is it new? Did you perge the M.C. My best advice is to take it to a break shop and get it power bled, you dont want to mess around with your breaks!!! I took my car down to a shop after i messed it all up seemed i had leaking wheel cylinders, so i fixed all that now i got a great responding pedal.
good luck
Old Apr 13, 2006 | 09:53 PM
Tyson's Avatar
sounds like you still have air.
did you bench bleed the MC before putting it on? you need to do that before you put the MC on, or else you wont get the air out.
Old Apr 14, 2006 | 12:05 AM
SloA$$ DA's Avatar
Default Re: brakes..... very spongy cuase? (Tyson)
yep benched bled the mc... kinda irritating cuz i cant get my heel toe lined up correctly before i enter a turn because my brakes are so damn low i either over blip the throttle or under blip the throttle.
father figure how much does it cost to get the brakes power bled? ive changed my mc before but just wondering if it worth it just to have a shop do it... oh an yes the mc is new.....
Old Apr 14, 2006 | 10:09 AM
wtfda88's Avatar
make sure ur booster is tight and that u got all the air out id bleed the whole thing again but thats jus cause i dont like taking my ish to anywhere
Old Apr 14, 2006 | 10:13 AM
Tyson's Avatar
you know, another thing ive heard is that there is an oring on the inside flange of the MC that often gets stuck to the firewall when you remove the old MC, and stays there when you put the new one on. so you now have two orings and may be the cause of the bad pedal feel.
i dunno, worth a check.
Old Apr 14, 2006 | 10:19 AM
roterx7's Avatar
bleed you master then bleed your breaks. a lot of air must have entered your system.
Old Apr 14, 2006 | 11:13 AM
8atman's Avatar
Default Re: (roterx7)
yeah it sounds like air in the lines, also you might have to adjust your booster which can be a bitch. Check your helms there is lots of info on it in the break booster section, also adjust your pedals pritty easy just takes time to find the sweet spot. Good luck let us know when you figure it out.
If you need refrence check out the faq's link on the front ef page look for manual's to download.
peace
Old Apr 14, 2006 | 12:04 PM
thesmogman's Avatar
You have bled your brakes wrong.
1. left front
2. right rear
3. right front
4. left rear
You have proportioning valve on both sides that is way you need to do it in this order.
Also there is a adjustment for the pedal height on the plunger.
Old Apr 14, 2006 | 01:38 PM
roterx7's Avatar
Default Re: brakes..... very spongy cuase? (thesmogman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesmogman &raquo;</TD></TR><TR><TD CLASS="quote">You have bled your brakes wrong.
1. left front
2. right rear
3. right front
4. left rear
Also there is a adjustment for the pedal height on the plunger.</TD></TR></TABLE>
that is wrong. it is
right rear
left front
left rear
right front
for 88-95 hondas
but he is right if you have a 84-87 honda
Old Apr 14, 2006 | 03:56 PM
bossman032's Avatar
Default Re: brakes..... very spongy cuase? (roterx7)
maybe someone pissed in your master cylinder
Old Apr 15, 2006 | 12:19 PM
SloA$$ DA's Avatar
Default Re: brakes..... very spongy cuase? (bossman032)
thanks for the info guys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">maybe someone pissed in your master cylinder </TD></TR></TABLE>
you know it wouldnt surprise me..... if some one did lol!
1sikhatch
Dec 7, 2009 04:18 AM
90 ef
Oct 29, 2009 12:03 PM
pedroa06
Sep 3, 2009 06:23 PM
ice11honda
Feb 24, 2005 12:56 PM
FastSS
Jul 8, 2004 12:23 PM
