1st gen vs. 2nd gen AEM EMS
Old Apr 13, 2006 | 01:55 PM
JDM B16 EK's Avatar
Default 1st gen vs. 2nd gen AEM EMS
i think this is the right form for this....
-does anyone have a picture of them side by side...i would like to see how much smaller the new one is compared to the old one.
-also, is the new one the same as the old one, but just more compact or are there new features?
-reason being i found one of both and deciding which one to buy...because obviously the 1st gen will be cheaper but im wondering if the new will be worth the extra $$$.
TIA
Modified by JDM B16 EK at 1:57 PM 4/15/2006
Old Apr 14, 2006 | 08:39 PM
JDM B16 EK's Avatar
Default Re: 1st gen vs. 2nd gen AEM EMS (JDM B16 EK)
ttt
Old Apr 15, 2006 | 08:35 PM
JDM B16 EK's Avatar
bump
Old Apr 17, 2006 | 10:29 AM
JDM B16 EK's Avatar
Old Apr 17, 2006 | 10:56 AM
tgreaves's Avatar
The only difference(obd1 models anyway) is the size and the 2nd gen on has extra coil outputs on it.. I am upgrading mine and getting the 2nd gen one, get the 30-1040u with the intergrated wideband in it..
Modified by tgreaves at 3:12 PM 4/17/2006
Old Apr 19, 2006 | 09:15 PM
JDM B16 EK's Avatar
Default Re: 1st gen vs. 2nd gen AEM EMS (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">The only difference(obd1 models anyway) is the size and the 2nd gen on has extra coil outputs on it.. I am upgrading mine and getting the 2nd gen one, get the 30-1040u with the intergrated wideband in it..
Modified by tgreaves at 3:12 PM 4/17/2006</TD></TR></TABLE>
so it is just the size...what do the coil outputs do? and would you need more than one?
are you upgrading for the extra coil and size or just bececause you want the intergraded wideband in it?
and thank you for you info
Old Apr 20, 2006 | 06:11 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM B16 EK &raquo;</TD></TR><TR><TD CLASS="quote">
and thank you for you info</TD></TR></TABLE>
The outputs are for direct fire setups.. You can do a wastefire setup with any of the boxes but the newer boxs are needed for direct fire(dont know why you would do that setup anyway).. I am upgrading because of size and integrated wideband..
hatchness135
Jan 7, 2007 02:27 PM
JDM B16 EK
Apr 20, 2006 03:41 AM
twilightprotege
Sep 27, 2005 07:26 PM
