anyone ever replaced a tranny?
just curious how it goes on a s2000. ive heard they are a bitch, from a honda technician. how did you fare?
possible to do without a lift?
ive replaced engines and transmissions multiple times on my crx to give you an idea of my mechanical aptitude.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">just curious how it goes on a s2000. ive heard they are a bitch, from a honda technician. how did you fare?
ive replaced engines and transmissions multiple times on my crx to give you an idea of my mechanical aptitude. </TD></TR></TABLE>
It's a pain for someone that hasn't done it before. It's possible without a lift but MUCH easier with one. To access the bolts at the top of the bell housing, you'll need to lower the sub-frame/engine. There are plenty of shortcuts that eliminate the steps in the manual. A good mechanic shouldn't have any problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">just to make sure, are you guys speaking from experience?</TD></TR></TABLE>
I tend to make up stuff from time to time just to make life harder for you, only you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">come on its honda-tech ....
I just finished putting a clutch in a '00. This is the fourth S2Kclutch I have done so it is becoming routine. Get a factory manual and follow it step by step and you won't have any problems. It is time consuming, but if you have swapped motors you can pull this trans.
*One good tip the manual doesn't show is to remove the alternator to access the upper starter bolt.
**Buy a new 6mm allen socket for the drive shaft bolts and I would also buy new driveshaft bolts from Honda...you will most likely round off a few.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">yeah i know. im feeling around which site to ask which questions.</TD></TR></TABLE>
haha, i do that all the time...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattb1 »</TD></TR><TR><TD CLASS="quote">you might checkout s2ki.com, I know there are people there who have swapped motors, AP2-AP1</TD></TR></TABLE>
It's been done here also.
perhaps the PN difference is in a different liner or whatnot. like they might have made a slight design change to make it beefier or less vibration. but still interchangeable.
i guess what im after is if they are interchangeable, at least will i need to get a new clutch or maybe another pressure plate or something.
