auto tranny fluid
Old Apr 13, 2006 | 10:16 AM
mark_is_gay's Avatar
Default auto tranny fluid
i want to change the fluid out on my 93 wagon accord, and cant seem to find any diy with pics. can anyone help me out, i am not sure how this is done, and i dont want to take it to jiffy lube. Where to drain the fluid from? how many bottles of auto tranny fluid do i need to fill it up again? thankss
Old Apr 13, 2006 | 10:33 AM
BLKFLSH's Avatar
Default Re: auto tranny fluid (mark_is_gay)
There is a drain plug on the bottom of the transmission. I think you need a 3/8 " drive to remove the plug. You may want to use a new crush washer when re-installing the plug. There is a magnet on the plug (to catch small particles that float by. If it has never been changed there will probably be a wad of it on the magnet. Wipe the stuff off the magnet, put the plug back in, and fill the trans back up. You have to fill the trans through the dipstick hole, so you will need a narrow funnel. Use only Honda ATF-Z1 (no additives). Should not take more than 3 quarts, but you may want to get 4, just in case. If you don't use it this time, you can always save it for the next change. Anything else? Good luck
PS: You may want to measure how much fluid drains out, so you will know about how much to pour back in. It can save you the constant dipstick checks
Old Apr 13, 2006 | 11:20 AM
Default Re: auto tranny fluid (BLKFLSH)
thanks for the help. I dont have any honda tranny fluid, but i have valvoline dectronn 3 or something. would that be fine? or should i only fill up honda stuff? i just picked up 4 quarts at kragen.
Old Apr 13, 2006 | 11:26 AM
Ross 2.0's Avatar
In a Junkyard near you.
you can use the other fluid but ATF-Z1 definately is better for a Honda. Usually other fluids cause rougher shifting and more gear hunting.
Old Apr 13, 2006 | 09:03 PM
Default Re: (MooGoCow3)
what exactly does gear hunting mean?......... i already filled it with the valvoline stuff, i will drive around on it for a thousand miles then just put the honda stuff u recomended in. thanks for the help
Old Apr 13, 2006 | 10:36 PM
accord-pro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH &raquo;</TD></TR><TR><TD CLASS="quote">. Should not take more than 3 quarts, but you may want to get 4, just in case. </TD></TR></TABLE>
if you are doing a tranny and refill.. DO NOT put in more than 3 qts ..
Old Apr 13, 2006 | 10:54 PM
Default Re: auto tranny fluid (accord-pro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord-pro &raquo;</TD></TR><TR><TD CLASS="quote">
if you are doing a tranny and refill.. DO NOT put in more than 3 qts ..</TD></TR></TABLE>
it only took about 3. what will happen if u put in more, overflow? or expletive something up.
Old Apr 14, 2006 | 07:54 AM
lunarone's Avatar
I did this about two weeks ago. It is really simple. First, jack up the car by the front tow points. Place the jackstands under it for safety reasons. Then, on the inside of the passenger wheel there is a place to unscrew the drainplug with a 3/8 ratchet. Unscrew and clean up the horrible mess that may be on the drain plug's magnet. In my case, it was a horrible mess. Then, replace the plug, refill tranny, constantly checking for fluid to come upon the hatches on the dipstick. Once you see the fluid in the crosshatch area, lower vehicle and start it. Shift slowly through all gears and repeat about 2-3 times. Then, drive around happily with your new fluid. Or, if the fluid was really bad, you can repeat the process a few times to make it even better. In my situation, I ordered a case of 12 bottles and I repeated the process twice last week, and I am going to do it again in soon to make sure its nice and clean.
Old Apr 14, 2006 | 12:03 PM
Default Re: (lunarone)
yeah, i am gonna do the same. i put some other atf oil in instead of the honda that everyone recommends. I just picked up 8 bottles, and will do it 2 more times. The magnet was a mess and a half, that **** looked like don kings hair, only in silver metal particals. anyways thanks for the help guys, appreciate it
Old Apr 14, 2006 | 04:00 PM
BLKFLSH's Avatar
PS: You may want to measure how much fluid drains out, so you will know about how much to pour back in. It can save you the constant dipstick checks</TD></TR></TABLE>
I meant to get 4 quarts just in case 3 was not enough. My new Accord says 3.1 or 3.2, but it only took 3 also.
Old Apr 14, 2006 | 04:49 PM
YeuEmMaiMai's Avatar
fill the trans up until the Full mark is reached. Start car, let it warm up and move selector through all gears. Turn off car and check again. if needed add more fluid.
northkai3
26
Sep 29, 2013 11:53 AM
alexdc03
Mar 26, 2012 04:40 PM
garrybloom
Dec 12, 2005 04:16 PM
dork
Jul 9, 2004 02:01 PM
4doorLX
Oct 2, 2002 10:55 AM
