Idle jumps between 1k and 2k PLEASE HELP ME!!!!!!!
Old Apr 13, 2006 | 10:02 AM
TurboJdmEF9's Avatar
Default Idle jumps between 1k and 2k PLEASE HELP ME!!!!!!!
i am buying a ef civic hatch with a gsr block and b16 head its slammed on tokiko blues and nuespeed springs has msd ignition aem intake and some other bolt ons now i heard this was a sick *** setup is it true? but now when i start the car and put it in nuetral and let it idle it jumps and drops from 1k to 2k back down to 1k rpms ALL THE TIME!!! does anyone know what this could be a friend said it was a vaccum line problem can anyone please tell help me asap any info would be awesome
Old Apr 13, 2006 | 10:23 AM
Default Re: Idle jumps between 1k and 2k PLEASE HELP ME!!!!!!! (TurboJdmEF9)
ttt please some one help me i know someone knows what it is
Old Apr 13, 2006 | 11:49 AM
EF_9's Avatar
fast idle thermo valve
it shows you how to fix it on the faq section
Old Apr 14, 2006 | 06:45 PM
thanks imma go look now thanks
Old Apr 14, 2006 | 06:49 PM
Tippyman's Avatar
After I did my swap it did that. Turns out it was just the Idle Screw! It's a little flathead screw above where the intake tube meets the intake manifold. Mine was a little loose so i tightened it down and it is perfect now!
Old Apr 14, 2006 | 07:44 PM
eda6's Avatar
Default Re: (Tippyman)
probably the fitv. what intake manifold are you using?
My car idles great w/o the fitv. i think you should remove it.
bmanuhutu
Apr 26, 2010 07:41 AM
rsa0905
Feb 27, 2010 07:01 AM
wilrock
Apr 4, 2006 05:56 PM
dustinsterk
Dec 31, 2003 04:10 AM
nicksweetlude
Mar 1, 2002 12:44 PM
