Steering wheel return-spring tension
Old Apr 6, 2002 | 10:18 AM
LudemanDan's Avatar
Default Steering wheel return-spring tension
I have the impression that the return springs are adjustable, and with a few tools I can raise the tension a bit. Is this true? Steering feels really light at the limits. The Chilton manual doesn't say anythinga about it, so I'm wondering if you guys know. I have a '93 Prelude. Thanks.
-Dan
Old Apr 6, 2002 | 10:36 AM
il8apex's Avatar
New User
Default Re: Steering wheel return-spring tension (LudemanDan)
Steering wheel return springs? Are you kidding?
-T
Old Apr 6, 2002 | 03:56 PM
Lsos's Avatar
There's no springs, man. It's called caster. Because of it, you are slightly lifting the car when you turn the steering wheel. The car wants to go back down, and hence the steering wheel centers.....
Old Apr 6, 2002 | 04:45 PM
earl's Avatar
Default Re: Steering wheel return-spring tension (Lsos)
Put a new set of tires on the front and as if by magic, the steering wheel return spring pressure will change.
Old Apr 7, 2002 | 11:13 PM
PyroVTEC's Avatar
New User
Default Re: Steering wheel return-spring tension (earl)
Ya, and make sure they're wider and bigger tires too.
Old Apr 8, 2002 | 10:58 AM
LudemanDan's Avatar
Default Re: Steering wheel return-spring tension (PyroVTEC)
Actually, I replaced my 185/70/14's with 205/60/14's and I think the steering got lighter! I was a little disappointed. Maybe it's due to the higher pressure rating. I get to keep these puppies at 44psi.
-Dan
Old Apr 8, 2002 | 06:38 PM
Jeef's Avatar
a higher pressure is not always desireable... just b/c a tire can have a max of 44 psi in it doesn't mean you should max out the tire...
Old Apr 8, 2002 | 06:54 PM
B18C-EJ1
Guest
Posts: n/a
Yea, I think that kragen sells them. I saw the package next to the JDM blinker fluid.
Don't forget to fix that noisy muffler bearing too.
huckaboo
Suspension & Brakes
Apr 7, 2009 02:20 PM
niceprelude
Jan 30, 2009 07:50 AM
05civicdriver
Honda Civic (2001 - 2005)
Nov 26, 2008 07:30 PM
steadysupreme
Mar 23, 2008 01:04 PM
BrokenRex
12
Nov 16, 2005 07:39 PM
