Help with Speedometer and VSS
ive searched and searched and searched, ive got the wiring hooked up, but my speedo does not go below 20 mph on or off, and when i turn the key to the acc position its jumps up to 30 and doesnt go up or down while im driving im so stupmped been out there all morning someone respond to me today please i need to know how fast i am goin
heh, mine does the same thing. i got the vss from a 92 civic d15 tranny, but i could not get it to work with the dx d15b2 in my crx. so i am waiting till i get the b18 swapped in there. as for speed, i just go with the flow of traffic, and if there is none around, i drive a lil slower than what i normally would drive..which is usually 10 miles over anyways.. so i should be doing the limit.. hehe
Code?
What kind of VSS do you have? Electric or Cable?
Check the VSS if it is in good working order. Make sure the cable is in all the way. Make sure its not snapped. Is the cluster good?
no code...my miles are being counted n everything everything else works...its and electronic VSS a 2000si cluster wired up in a EF.
I know it's not what you want to hear but the same thing happened to me. I ended getting another speedometer and it works fine. You don't need an Si speedo as a replacement just get a cheaper one and put your Si face on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnieChimpo »</TD></TR><TR><TD CLASS="quote">I know it's not what you want to hear but the same thing happened to me. I ended getting another speedometer and it works fine. You don't need an Si speedo as a replacement just get a cheaper one and put your Si face on it.</TD></TR></TABLE>
superslowcrx91
May 8, 2013 08:10 PM
rasta420
Jul 7, 2002 07:50 PM
