1993 Accord EX auto tranny problem
Old Apr 13, 2006 | 08:56 AM
jayp4757's Avatar
Default 1993 Accord EX auto tranny problem
I am currently working on my 1993 Accord EX. The problem I am having is a noice when I shift from neutral to drive. I hear a loud clang. Essentially, it is shifting pretty rough. The noice only occurs when shifting through those two gears. Otherwise the car starts/drives fine.
I have flushed the tranny fluid in it and checked the computers. Beyond that I am pretty clueless on what it could be.
Any suggestions/tips?
Old Apr 13, 2006 | 10:44 AM
BLKFLSH's Avatar
Default Re: 1993 Accord EX auto tranny problem (jayp4757)
Did you use Honda fluid? If the fluid was really dirty, you may need to change it again. Three changes, with a short drive in between is considered a flush in the Accord service manual. A simple fluid change only replaces a little more than half of the flluid that's actually in the transmission. Of course there is no guarantee this will help. Worth a shot, IMO though. Beats waiting for the trans to totally give out on you.
Old Apr 13, 2006 | 11:50 AM
Ross 2.0's Avatar
In a Junkyard near you.
Also if the car was in reverse the last time it moved it's going to have the clunk. That's normal. But if you do Drive - Neutral - Drive and it still makes the same noise you may have an issue.
Old Apr 14, 2006 | 11:49 AM
jayp4757's Avatar
Default Re: (MooGoCow3)
I'll check all of those tomorrow and let you know.
Thanks guys!
Old Apr 14, 2006 | 08:47 PM
myrevenge's Avatar
Default Re: (jayp4757)
sounds like the forward clutches wont engadge right, im not too well versed in auto trannys, but i can tell you, auto trannys in cb7's = biggest peices of **** on the plannet... dump that ******* thing and grab a transmission from a Prelude Si... get a new presure plat, throw out berrings and OEM clutch (sorry guys, but "high preformance" clutches are my bitch!) and call it a day, next time you feel like killing some rubber, all you have to do is drop the hammer and strip the rubber! have fun!
dishka
Aug 9, 2009 01:21 AM
josebaldy
Jun 21, 2006 01:25 PM
knucklehead11
May 5, 2006 05:35 PM
MetRX10
Aug 22, 2004 11:15 AM
