help me out more starting issues :(
ok so i went through my car and fixed everything, the fuel issue and timing as well....the timing is good as far as i know, but theres one problem. on the number one cylinder theres no fuel getting to it. I tried to turn the car over several times and theres only the smell and look of fuel on three out of the four cylinders. the one that isnt getting fuel is the one on the far right. Thats the first one in the firing order according to my chilton manual. Whats wrong with my car? is it bad injectors or just messed up timing i dunno guys
help thanx
help thanx
did you have to do DP to MPfi. check thoes wires or maybe the injector is clogged. sometimes if you give a litte tap, the injector will begin to work
edit... I just seen the link in the sig. forget what I said about the dp to mp
well my grounds are good i just went through all of them earlier this week and timing i dont have a timing light so i cant check that as of right now and i got new wires but i need new plugs....maybe that is the problem?
sg
Sep 8, 2008 09:11 PM
kreush33
Apr 3, 2004 05:16 PM
