shift light in stock gauge
Old Apr 13, 2006 | 03:52 AM
el_toro_de_magnifico's Avatar
Default shift light in stock gauge
can this be done? anyone know how? i saw a vid of a civic with this built in the gauge.
Old Apr 13, 2006 | 08:49 AM
Chris22215's Avatar
Default Re: shift light in stock gauge (el_toro_de_magnifico)
if you use crome or hondata, you can set up the check engine light to come on at a set rpm.
Old Apr 13, 2006 | 10:00 AM
ROOROWNS's Avatar
Get an HX and you'll have an upshift light at the most economical point in each gear
But yes uberdata, chrome, etc. all have the Check engine shift light I believe.
Old Apr 13, 2006 | 12:25 PM
Kelly.'s Avatar
I've quit using this account
there is also adjstable shift lights that you can use.
you tap into the rpm signal and adjust the dial on the back (to tell it when to light up)
similar to this one:
http://www.eautoworks.com/html/ORD-1-1-1-1898.cfm
(i just googled it and used the first link as a reference, im sure there are others for cheaper that work similar)
i used my CEL through neptune.
at first it takes alittle getting used to. (at the top of a 3rd gear 25 psi pull the last thing i want to see is a CEL)
chrisfromsrq
Jul 27, 2009 01:20 PM
CeeJayy
10
Aug 21, 2006 03:11 PM
CeeJayy
Aug 16, 2006 05:09 PM
Junkyard2000
Nov 13, 2005 04:06 PM
RCSIVTEC
May 29, 2002 12:12 AM
