help -> Hood latch cable stuck open!
Old Apr 6, 2002 | 08:46 AM
brcivic411's Avatar
Default help -> Hood latch cable stuck open!
Okay, here's the deal:
My hood latch cable is stuck out... meaning, I pulled the cable from inside the car, the hood opened correctly, but the cable did not return to it's original position!!! so now my hood won't close shut.
I tried hammering in the cable from inside the cabin but no luck. (it's stuck out)
I took off the bumer and removed the entire hood latch assembly but it's not the problem.
somewhere between the cable from inside the cabin and the cable connected to the hood latch assembly is the problem. anybody encounter this before and have any solutions? do i need to take off my front drivers side panel to get to another mechanism?
HELP!
Old Apr 6, 2002 | 09:08 AM
poison's Avatar
Default Re: help -> Hood latch cable stuck open! (brcivic411)
HELP!
hey, i used to have this prob, well sort of, heh, i just pulled the cable from under the lever inside the cabin, then i actually looked under there and saw it was not hooked up to pull from (there's a lil white piece that is held on there to pull cable from), other wise you are just pullin the WHOLE thing.
i'd take off the latch off the front, have another person pull the lever from inside of the cabin and see if it pulls, then pull the handle on the latch to put it back....
if that doesn't work for ya, u might wanna get another hood cable assembly, or find where the hell the prob is, orrrrrrr, you could just get TIGHT *** hood pins haha
what can i say tho, i have hood pins....just for back up
[Modified by poison, 11:09 AM 4/6/2002]
Old Apr 8, 2002 | 11:37 AM
brcivic411's Avatar
Default Re: help -> Hood latch cable stuck open! (poison)
yeah, i took everything apart and figured that the problem is somewhere inbetween the latch assembly and the cabin... looks like i'm gonna be removing the front driver panel
Old Apr 8, 2002 | 01:41 PM
kyler's Avatar
actually you dont have to remove the panel... just take off the wheel and inner fender liner and you can fish the new cable through using a bent up coat hanger and electrical tape....
Old Apr 8, 2002 | 01:43 PM
brcivic411's Avatar
Default Re: help -> Hood latch cable stuck open! (kyler)
true.. but before i have to buy a new cable.. i want to see if i can salvage the existing one. unless you guys think it's broken!
Old Apr 9, 2002 | 06:18 AM
brcivic411's Avatar
i guess there's a kink.. but here's what's confusing me: I did separate the cable from the latch and it ALREADY IS in the protective covering all the way. At the same time, the cable is sticking out inside the cabin. (btw, my handle is broken off the cable in the inside).
how hard is it to replace the cable??
Old Mar 4, 2006 | 02:07 PM
BLUE EH3's Avatar
Help we my pennies
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brcivic411 &raquo;</TD></TR><TR><TD CLASS="quote">i
how hard is it to replace the cable?? </TD></TR></TABLE>
Old Mar 4, 2006 | 02:51 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: help -> Hood latch cable stuck open! (BLUE EH3)
This is back from the dead.
Replacing the cable is not that hard. You need to remove the fender liner and the driver kick panel. You may want to reroute the cable at this time to ward of thieves.
TanEJ1
Sep 28, 2014 06:01 AM
mortificationrock
Nov 20, 2008 08:56 PM
pinecone
May 16, 2006 05:56 PM
DsMWookie
Sep 14, 2005 09:04 AM
brcivic411
Apr 9, 2002 07:06 AM
