Denso Iridium Spark Plugs
Old Apr 6, 2002 | 08:36 AM
aznchino16's Avatar
Default Denso Iridium Spark Plugs
wassup guys,
I can't decide if i should get the Denso Iridium Spark Plugs IK16 or IK20. Someone please inform me about it. Thanks!
Old Apr 6, 2002 | 08:56 AM
Kazmans94cord's Avatar
Default Re: Denso Iridium Spark Plugs (aznchino16)
i dunno know bout those..but i got some NGK platnuims are they are pretty good i guess
Old Apr 6, 2002 | 09:04 AM
4doorH22's Avatar
For what motor and what modifications?
Old Apr 6, 2002 | 09:09 AM
97accordex's Avatar
There are so many archived posts on plugs. Do a search.
Most plug manufacturers have websites where you can cross reference the "other guys" plugs. Denso's are pricey and unless you are running some high powered stuff you will probably reap benefits.
Any fresh plug (in the right heat range) will usually provide some noticable performance improvement till it gets a few miles on it.
Try AC delco's for $1.50 each. When they are fresh they are as good as a $6 plug.
Old Apr 6, 2002 | 09:13 AM
4doorH22's Avatar
if you've got basic bolt-ons I'd say save your money and get some regular OE non-platinum NGKs. I think the # is ZFR5-11F...
Old Apr 6, 2002 | 01:41 PM
Tlex's Avatar
Default Re: Denso Iridium Spark Plugs (4doorH22)
I agree with 4DoorH22. Just get NGK non-platinum and you should be fine. In fact, I would get maybe 1 temperature cooler so that would mean part # ZFR6-11F
Old Apr 6, 2002 | 02:53 PM
ArchAngel Sabastian's Avatar
New User
Default Re: Denso Iridium Spark Plugs (Tlex)
bosch oWnZ yoU - import review tested and noted that bosch plat +4's dynoed for more hp on a civic with I/H/E. so why still the hype about NGK's?
Old Apr 6, 2002 | 02:54 PM
New User
Default Re: Denso Iridium Spark Plugs (Sabastian)
http://www.importreview.com/reviews/BoschVSNGK.html
thats the test on a D16 i couldnt find the other civic test.
bosch makes power
Old Apr 6, 2002 | 05:06 PM
CmptchAV6's Avatar
Yeah and if you check the boards on http://www.v6accord.com the Denso's make about 8hp to the wheels alone on the dyno. They are expensive but they work way better than the stock NGK Platinums do in the V6 Accord.
Old Apr 6, 2002 | 07:30 PM
New User
Default Re: Denso Iridium Spark Plugs (CmptchAV6)
whats the stock plug?
Old Apr 6, 2002 | 08:19 PM
SOHCArchangel's Avatar
forget bosch
forget denso
forget ngk
Torqumasters 0wnz j00!!!!
Old Apr 7, 2002 | 03:20 PM
bmm89's Avatar
accord is ik20 for 4 bangers, ik16 for 6(hotter)
Old Apr 7, 2002 | 03:42 PM
RJonathan's Avatar
IK16 is for Bolt on and IK20 is if your Spraying Nitrous.. That what people at performance shop told me but I might be wrong.. But to my opinion use IK16
Old Apr 7, 2002 | 06:04 PM
97accordex's Avatar
After reviewing the Bosch and Denso dyno charts, I am convinced that a good clean, new, properly gapped and correct heat range set of plugs will get you a few more horses to the wheels. It does not matter whose plugs they are but the overall condition of your motor and set up will matter.
A spark plug is designed to spark when a voltage is supplied to it. Pretty simple device.
Old Apr 7, 2002 | 07:16 PM
aznchino16's Avatar
Default Re: Denso Iridium Spark Plugs (97accordex)
well, i have an 98' accord 4 cycl. So far i have i/h/e and pulley kit and cam gear. That's why i ask if i should use the IK16 or the IK20. I think i would be spraying soon though. Also, i heard Bosch is only good for Euro cars.
Old Apr 8, 2002 | 01:12 PM
bmm89's Avatar
Denso says ik20, nuff said http://www.iridiumpower.com
Old Apr 8, 2002 | 01:25 PM
TypeSH's Avatar
Default Re: Denso Iridium Spark Plugs (bmm89)
If you are gonna go w/ Iridium plugs, check the NGK IridiumIX plugs. I've found them much cheaper than the denso ones, got mine for $6.50 a piece plus shipping and tax. http://www.sparkplugs.com
I noticed 2-3mpg gains w/ brand new iridium plugs and ngk wires, but i'm sure most of the gains is just due to the fact that my old plugs and wires were really corroded. I'd like to see some real world dynos comparing brand new copper, platinium, bosch platinum 4+, and iridium plugs... not just one run, but several runs of each, to get a consistant dyno.
I've seen some dyno comparisons that compare their old copper plugs to new iridiums... which would almost guarentee that the newer plugs should perform better. Such a waste of dyno time for those comparisons.
jdmturbo1127
May 21, 2007 12:29 PM
nsx-Animal
Jul 30, 2002 04:22 AM
Brandon
Jun 17, 2002 07:25 PM
mattmw88
Feb 22, 2002 07:54 AM
