DIY: Coating a header.
Old Apr 12, 2006 | 07:37 PM
danielm3's Avatar
Default DIY: Coating a header.
I have a mild steel header I want to coat inside out, before I contact Jet Hot and companies a like is there a way i can do it my self? The outside seems like it wont be too hard, but how to do the inside?
Thanks.
Old Apr 12, 2006 | 08:56 PM
delspool's Avatar
Default Re: DIY: Coating a header. (danielm3)
for the price, it would probably just be easier to send it somewhere that offers a gaurantee, that way if it ever cracks or anything, you could send it back
im normally all for diy projects; but just stating my opinion, if you go ahead with it, good luck with the project
Old Apr 12, 2006 | 09:54 PM
danielm3's Avatar
Default Re: DIY: Coating a header. (delspool)
Yeah I like doing things my self too, but not always possible .
Ok another question, how important is it to coat the inside?
Old Apr 13, 2006 | 09:58 AM
.dave's Avatar
i HAS questions ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danielm3 &raquo;</TD></TR><TR><TD CLASS="quote">Ok another question, how important is it to coat the inside?</TD></TR></TABLE>
It depends on who you talk to. Some companies like Jet-Hot I believe will coat the inside. Others, such as Swain-Tech which uses a much thicker ceramic coating, say that it is unnecessary and often not possible to prep the inside surfaces for proper adhesion.
I want to perform a test on identical manifolds, coated by different companies, on a dyno to see differences in temperature over time. Hopefully I can get a TIG welder soon and get started on this.
Old Apr 14, 2006 | 04:05 PM
Bailhatch's Avatar
Default Re: DIY: Coating a header. (daveG)
I would love to see the same manifold on the same car with both in and out coated and just outside. I never try and coat in further than I was able to sandblast when I do manifolds. Big chunks of coating going through your turbine wheel, o2 sensors and cat doesnt seem like a good idea.
ericstambaugh07
May 27, 2007 06:15 PM
93h22a1vtec
Mar 8, 2007 11:05 AM
the soL that could
May 18, 2006 11:20 PM
xmr. robotox
Feb 7, 2005 07:57 PM
latindc2
Jan 7, 2005 03:10 PM
