If 19" x 8.5" wheels Fit>>>
Old Apr 12, 2006 | 07:36 PM
Avaya22's Avatar
Default If 19" x 8.5" wheels Fit>>>
Hello all...
I have a 2003 Honda Accord Ex. I'm wanting to put 19" x 8.5" wheels on the car. i have found some that i would like BUT... i dont know they ( DUB Dirty Dog 5's) will fit. thiz are the offset that i have found for the wheel:
19" x 8.5" 5/114.3 offest ---34
19" x 8.5" 5/114.3 offset ---45
what do u all think...
Old Apr 12, 2006 | 08:24 PM
kbanks45's Avatar
Default Re: If 19" x 8.5" wheels Fit>>> (Avaya22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Avaya22 &raquo;</TD></TR><TR><TD CLASS="quote">Hello all...
Yes they will fit, I think 8.5 is pushing it a bit, but yes they will fit with no problem. Make sure you go with a 235/35/19 for the tire size. That's as close as you will get to the factory rim and tire diameter. This will keep your speed-odometer true. Hell, I have 20's on mine, I just had to go as big as I could without raising the car. Infact, I lowered my car (1.5 inchs). As long as you stay with the over all diameter, you can go as big as 20''. 03-06 have the biggest wheel wells of all the accords, so I took advantage of of it....
Old Apr 13, 2006 | 08:57 AM
d112crzy's Avatar
Its kinda funny how stupid and lazy noobs really are. There is a thread UBER similar to this just above it, well, there was, I just bumped this one up to the top.
Old Apr 13, 2006 | 12:35 PM
philadd's Avatar
Default Re: (d112crzy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d112crzy &raquo;</TD></TR><TR><TD CLASS="quote">Its kinda funny how stupid and lazy noobs really are.</TD></TR></TABLE>
Agreed.
First one, no way. Second one, cutting it close, but probably.
Old Apr 13, 2006 | 12:46 PM
kbanks45's Avatar
Default Re: (philadd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd &raquo;</TD></TR><TR><TD CLASS="quote">
Agreed.
First one, no way. Second one, cutting it close, but probably. </TD></TR></TABLE>
I say 19x8 at the most!!!! with a 45 offset, then lower it at least an inch...
Old Apr 14, 2006 | 11:41 AM
kbanks45's Avatar
Agreed.
Old Apr 15, 2006 | 03:43 PM
Avaya22's Avatar
Default Re: (kbanks45)
First off let me thank for the reply.. i should have explained this a lil more..but what i'm looking for is something (big wheel) with a lip on it. i choose the 19" x 8.5 because i figure i would beable to play with the offset. i thougt about doing the offset of 34 because i want the wheel to come out to the fender. and not stick in the the typical wheels. i have gone to tirerack.com and searched for wheels there and they say the 19" x 8.5" will fit... with no rub.. my question to u all or u (sense im a noobi) do u think this will work... im looking for pix with the offset and can't find one.. thank again..
Old Apr 15, 2006 | 08:35 PM
kbanks45's Avatar
Default Re: (Avaya22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Avaya22 &raquo;</TD></TR><TR><TD CLASS="quote">First off let me thank for the reply.. i should have explained this a lil more..but what i'm looking for is something (big wheel) with a lip on it. i choose the 19" x 8.5 because i figure i would beable to play with the offset. i thougt about doing the offset of 34 because i want the wheel to come out to the fender. and not stick in the the typical wheels. i have gone to tirerack.com and searched for wheels there and they say the 19" x 8.5" will fit... with no rub.. my question to u all or u (sense im a noobi) do u think this will work... im looking for pix with the offset and can't find one.. thank again.. </TD></TR></TABLE>
Well, what you want to do is get your regular offset that they recommend and the fact that the wheel you want is a 19x8.5 will bring the wheel out like you want. On a 7th gen, I wouldn't go no smaller than 235/35/19. A 225 will have to be stretched on a 8.5, which will look like garbage. Do the 235 and you will be fine. Only 03-06 can take that wide of a tire without having to change anything.....
Old Apr 16, 2006 | 01:37 AM
Doctor X's Avatar
They'll probably fit but it'll be definately a squeeze.
Old Apr 16, 2006 | 02:05 PM
kbanks45's Avatar
Default Re: (Doctor X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor X &raquo;</TD></TR><TR><TD CLASS="quote">They'll probably fit but it'll be definately a squeeze.</TD></TR></TABLE>
The guy next door to me has 8.5 on his 03, it will work...
Serstylz2
Feb 27, 2012 02:18 PM
sleepywagon627
Dec 30, 2010 12:20 PM
J_Marc
May 18, 2007 06:54 PM
hwoody77
Aug 8, 2006 03:48 PM
mckeand13
Jul 12, 2006 09:50 AM
