Fuel Cell Mounting Help
Old Apr 12, 2006 | 07:18 PM
93turbo16's Avatar
Default Fuel Cell Mounting Help
I am on to my next project, the fuel cell. I got the car with a fuel cell installed already. I am very sure this will not pass tech pretty much anywhere. So, is there anyway I can get this to pass. Can I build a box around the cell and close off the hole? The other option is to move it to the spare tire well and close it off.
Old Apr 12, 2006 | 07:22 PM
mrbsponge's Avatar
move it to the back, use the dip in the rear to send your feed line out.
build a box or "firewall" as the rule book states to seperate it from the driver
Old Apr 12, 2006 | 07:26 PM
93turbo16's Avatar
Default Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">move it to the back, use the dip in the rear to send your feed line out.
build a box or "firewall" as the rule book states to seperate it from the driver</TD></TR></TABLE>
That is probably my best bet.
But can I just build a wall around it the way it sits. All the fuel lines and pump are mounted pretty well.
Old Apr 12, 2006 | 08:07 PM
LSR-Abuser's Avatar
Default Re: (93turbo16)
should just order a 1 gallon jaz fell cell form jegs for 100 bucks or so and mount it in the front.like This.
Old Apr 12, 2006 | 09:30 PM
93turbo16's Avatar
Default Re: (LSR-Abuser)
I can't because my battery is on one side and the charge pipe is on the other.
94draglude
Jan 22, 2007 06:49 PM
fastasscrx
Oct 3, 2005 06:15 AM
LBR92DA-T
Oct 25, 2003 02:21 AM
EVIL_AWD
Jun 8, 2003 09:45 AM
