Suspension & Brakes Theory, alignment, spring rates....
bouncy
Old Apr 12, 2006 | 05:26 PM
Jxi8s2k's Avatar
Default bouncy
i just installed my koni yellows and ground controls like last week. after i put them on, i found that instead of having a stiffer ride, my car was alot more bouncy. i tried to put my koni's on the firmest setting, but the car bounces like crazy. is the only way to correct this problem is to purchase a new set of stiffer springs?
Old Apr 12, 2006 | 06:13 PM
alwaysoverkill's Avatar
Default Re: bouncy (Jxi8s2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jxi8s2k &raquo;</TD></TR><TR><TD CLASS="quote">i just installed my koni yellows and ground controls like last week. after i put them on, i found that instead of having a stiffer ride, my car was alot more bouncy. i tried to put my koni's on the firmest setting, but the car bounces like crazy. is the only way to correct this problem is to purchase a new set of stiffer springs? </TD></TR></TABLE>
and what stiffness are your current springs?
Old Apr 12, 2006 | 06:15 PM
Design's Avatar
What was the visual condition of the Koni yellows? Without more info, I would assume they are not dampening properly. Perhaps a weak or blown shock (shot in the dark)?
Old Apr 13, 2006 | 12:20 PM
TunerN00b's Avatar
Stiffer springs will make it bounce more. If it is indeed bouncing, you want more shock rebound, or less spring. If its just you not being used to the increased stiffness, then you'll just have to trake some time to adjust.
When I installed my GCs, I didn't cut the bumpstops, and it sits on them at ride height. I think between the springs (400/400) and the bumpstops, it might be more than the Konis can dampen, because even at full still, it bounces a little. Did you correctly cut your bumpstops, or are you too low and hitting even the cut bumpstops?
Old Apr 14, 2006 | 06:05 AM
Jxi8s2k's Avatar
Default Re: bouncy (TunerN00b)
nah i didn't cut my bumpstops. maybe i should do that. i think i only had bumpstops on the front struts...is that right?
Old Apr 14, 2006 | 10:17 PM
HONDA RR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jxi8s2k &raquo;</TD></TR><TR><TD CLASS="quote">nah i didn't cut my bumpstops. maybe i should do that. i think i only had bumpstops on the front struts...is that right?</TD></TR></TABLE>
You should have bumpstops on the rear struts as well.
Old Apr 16, 2006 | 05:46 AM
Jxi8s2k's Avatar
Default Re: bouncy (HONDA RR)
how much do i trim them?
Old Apr 16, 2006 | 08:26 AM
CRX Lee's Avatar
It sounds like a combination of regularly hitting your bump stops wich will make it quite harsh and also being over damped with too much rebound. Soften the shocks up to about 1 turn from soft and recheck your ride height and bump stop contact point. What are the spring rates?
Old Apr 16, 2006 | 09:41 AM
chrisw85's Avatar
also how low are you? how low you are can affect what spring rate you should run to prevent bottoming out.
Old Apr 17, 2006 | 03:56 AM
Jxi8s2k's Avatar
Default Re: (chrisw85)
i'm completely slammed. damn man...i'm such a noob with suspension. becuase it was so bouncy, i put it even more closer to stiff. its like almost completely on firm. becuase i'm slammed, how much should i trim the bumpstops?
Old Apr 17, 2006 | 08:06 AM
STN_Pat's Avatar
Default Re: (Jxi8s2k)
instead of cutting the bumpstop, raise the car.
Old Apr 23, 2006 | 05:23 AM
Jxi8s2k's Avatar
Default Re: (STN_Pat)
awww is that the only way. if so then damn. i really like the way it looks right now.
Old Apr 23, 2006 | 10:34 AM
8520's Avatar
^ That's slammed?
Old Apr 23, 2006 | 03:15 PM
shortyz21's Avatar
Default Re: (a_s_ol_)
with those rims + tires. yeah thats slammed.
Old Apr 26, 2006 | 05:34 AM
Jxi8s2k's Avatar
Default Re: (shortyz21)
so what should i do? raise it a little?
Old Apr 26, 2006 | 07:10 AM
CRX Lee's Avatar
Yes raise it up a bit to get is off the bump stops and soften the rebound damping down to between 1/2 to 1 turn from soft. The car will be much more livable. Trimming the bump stops a bit would be a good ideas and it should have bump stops on all four corners.
le0ftw
Oct 17, 2007 02:01 PM
snowblind7x
Feb 23, 2006 11:35 AM
alwaysoverkill
Suspension & Brakes
Oct 31, 2005 07:22 PM
blkgsr03
Dec 7, 2003 07:50 AM
Preludster
Nov 17, 2003 04:19 AM
