oil pressure gauge for you guy running bb turbos
Old Apr 12, 2006 | 01:29 PM
pip9's Avatar
Default oil pressure gauge for you guy running bb turbos
Im going to be running a gt28rs. trying to figure out how im going to run my oil lines and gauges.
For u guys running a bb turbo and an oil pressure guage.
do u have one guage for the oil pressure for the turbo and one for the engine oil pressure?
if so are u just running one before the oil resistor for the turbo and one after?
i'd like to see some pix of how u ran your oil lines too. thx.
Old Apr 12, 2006 | 03:20 PM
Boilermaker1's Avatar
I run an oil cooler loop and a GT28R
I have a line that runs from the block to a remote filter, the pressure sensor is mounted at the exit of the filter, it then goes through the cooler grid, then up the return line, the turbo line is plumbed half way between the cooler and the engine block in the return line. I don't see the point in a before/after turbo for pressure because the turbo is drawing off so little oil (a .035 restrictor vs a -10 line) its not going to have any major effect on the pressure.
Old Apr 13, 2006 | 11:19 AM
pip9's Avatar
Default Re: (Boilermaker1)
the reason i was thinking two gauges is because the turbo oil pressure is going to be awhole lot different than the engine oil pressure. i'd just like to monitor both of them.
anyone got any pix?
Old Apr 14, 2006 | 08:29 AM
pip9's Avatar
Default Re: (pip9)
TravisBiggie
Aug 20, 2013 07:48 PM
jdkornlp
Sep 10, 2005 06:07 PM
screen_name
Apr 23, 2005 07:22 AM
CRXDrew
Apr 14, 2005 03:55 PM
Firedrake
Sep 24, 2002 11:18 AM
