Best motor to boost?
Old Apr 12, 2006 | 09:25 AM
GuCCi_GSR's Avatar
Default Best motor to boost?
I was wondering what was the best Honda motor to boost. I don't have to go too crazy, just stock internals.
Can a B20 handle 7 psi?
Old Apr 12, 2006 | 09:33 AM
aaroboost's Avatar
Default Re: Best motor to boost? (GuCCi_GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GuCCi_GSR &raquo;</TD></TR><TR><TD CLASS="quote">Can a B20 handle 7 psi?</TD></TR></TABLE>
as long as you tune it right, probably. remember, boost in big turbo is different than boost in a small turbo.
Old Apr 12, 2006 | 09:50 AM
wpgredteg's Avatar
LS motor I think would be best to boost considering you wanna use stock internals
Old Apr 12, 2006 | 10:00 AM
JDM00SI's Avatar
Default Re: (wpgredteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgredteg &raquo;</TD></TR><TR><TD CLASS="quote">LS motor I think would be best to boost considering you wanna use stock internals</TD></TR></TABLE>
or ls vtec
Old Apr 13, 2006 | 08:24 AM
GuCCi_GSR's Avatar
why is LS (b18b) better than a CRV (b20)?
Old Apr 13, 2006 | 08:41 AM
631 Teggy's Avatar
Default Re: (GuCCi_GSR)
GSR...
.dave's Avatar
i HAS questions ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GuCCi_GSR &raquo;</TD></TR><TR><TD CLASS="quote">why is LS (b18b) better than a CRV (b20)?</TD></TR></TABLE>
B20 is a bored out LS. Thinner sleeves.
Old Apr 13, 2006 | 08:51 AM
GuCCi_GSR's Avatar
then why does a CRV make more power? Is it dangerous for a turbo?
and how much can i expect to spend on a small turbo kit?
Old Apr 13, 2006 | 09:19 AM
.dave's Avatar
i HAS questions ?
It has more displacement. Displacement = power.
Old Apr 13, 2006 | 11:56 AM
beerbongskickass's Avatar
Default Re: (daveG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daveG &raquo;</TD></TR><TR><TD CLASS="quote">
B20 is a bored out LS. Thinner sleeves.</TD></TR></TABLE>
No it's not. The B20's have thicker sleeves, but the design make them extremely weak. Don't waste you time on stock B20 sleeves, they are garbage, anything that tells you different doesn't know what they are talking about. Search and you will see plenty of info as to why they are crappy.
The best motor to boost? There is no such thing, but the B18c1/5 (GSR and ITR) are the best all around motors honda made in my opinion. You can use those motor for just about anything. Good r/s ratio, good stock heads and cams, and not much is needed to make big power with them.
Old Apr 13, 2006 | 12:07 PM
sp00led's Avatar
Default Re: (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">
The best motor to boost? There is no such thing, but the B18c1/5 (GSR and ITR) are the best all around motors honda made in my opinion. You can use those motor for just about anything. Good r/s ratio, good stock heads and cams, and not much is needed to make big power with them.</TD></TR></TABLE>
Well said
Old Apr 13, 2006 | 12:20 PM
.dave's Avatar
i HAS questions ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">No it's not. The B20's have thicker sleeves, but the design make them extremely weak. </TD></TR></TABLE>
Word. Didn't know that. I just mess with crappy SOHC engines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">The best motor to boost? There is no such thing, but the B18c1/5 (GSR and ITR) are the best all around motors honda made in my opinion. You can use those motor for just about anything. Good r/s ratio, good stock heads and cams, and not much is needed to make big power with them.</TD></TR></TABLE>
Agreed.
Old Apr 13, 2006 | 12:23 PM
SOHCEK-Turbo's Avatar
Default Re: (sp00led)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 631 Teggy &raquo;</TD></TR><TR><TD CLASS="quote">GSR...</TD></TR></TABLE>
Old Apr 13, 2006 | 12:32 PM
stockredej1's Avatar
I dont think there is a better answer then that
teggyjeff
Oct 30, 2008 03:26 AM
danno33
May 17, 2008 09:06 PM
JDMroyEG5turbo
15
Mar 3, 2006 03:01 AM
ras
May 3, 2005 09:14 AM
ragerized
35
May 10, 2004 12:22 PM
