CLUTCHMASTERS STAGE 3 CARBON KEVLAR DISC WITH ACT XTREME PRESSURE PLATE?
Old Apr 12, 2006 | 08:39 AM
b18sihatch's Avatar
Default CLUTCHMASTERS STAGE 3 CARBON KEVLAR DISC WITH ACT XTREME PRESSURE PLATE?
ok so i have 2 pressure plates a stage 3 heavy duty pressure plate that comes with the stage 3 setup, or a act xtreme pressure plate..... i have read that the common problems with clutch masters clutches is that the pressure plates just dont hold alot of power, but i figured wouldnt that problem be gone with a act xtreme pressure plate, or would you just stay with the clutchmaster pressure plate? give mesome advice on this
Old Apr 13, 2006 | 08:26 AM
b18sihatch's Avatar
Default Re: CLUTCHMASTERS STAGE 3 CARBON KEVLAR DISC WITH ACT XTREME PRESSURE PLATE? (b18sihatch)
bump
Old Apr 13, 2006 | 09:33 AM
b18sihatch's Avatar
ne 1 know?
Old Apr 13, 2006 | 04:45 PM
b18sihatch's Avatar
Default CM Carbon Kevlar stage 3 disc with act xtreme pressure plate what do you tihnk of this setup
does anyone have a opinion on this setup
Old Apr 13, 2006 | 05:05 PM
StolenTeg's Avatar
Default Re: CM Carbon Kevlar stage 3 disc with act xtreme pressure plate what do you tihnk of this setup (b1
Umm im using the stage 3 and it holding fine
Old Apr 13, 2006 | 07:04 PM
b18sihatch's Avatar
how do you think it ould be with a act xtreme pressure plate
Old Apr 13, 2006 | 07:45 PM
redzcstandardhatch's Avatar
something different
if they are for the same application, they are the same size, so i see no problem with doing it.
i'm running a clutchmasters pressure plate (some super heavy one, like stage 3 or something)with a centerforce dual friction kevlarpuck/organic face disc. works great.
Old Apr 13, 2006 | 07:53 PM
2k.civic.si's Avatar
Default Re: (redzcstandardhatch)
if you dont mind the extra force it takes to push down the clutch petal use the act pp
Old Apr 14, 2006 | 11:24 AM
b18sihatch's Avatar
did you improve the clamping load on the disc? or the entire clutch setup? having a better pressure plate than a heavy duty had to imporve sumthing, other than a tighter pedal feel
Old Apr 14, 2006 | 01:50 PM
1320me's Avatar
im using a a stage three clutch master and it holds so far
oldskoolracer
May 24, 2007 06:45 PM
wilntegra
Jul 16, 2005 06:42 AM
crxracer2
Oct 25, 2004 01:52 AM
