CLUTCHMASTERS STAGE 3 CARBON KEVLAR DISC WITH ACT XTREME PRESSURE PLATE?
ok so i have 2 pressure plates a stage 3 heavy duty pressure plate that comes with the stage 3 setup, or a act xtreme pressure plate..... i have read that the common problems with clutch masters clutches is that the pressure plates just dont hold alot of power, but i figured wouldnt that problem be gone with a act xtreme pressure plate, or would you just stay with the clutchmaster pressure plate? give mesome advice on this
something different
1 Post
if they are for the same application, they are the same size, so i see no problem with doing it.
i'm running a clutchmasters pressure plate (some super heavy one, like stage 3 or something)with a centerforce dual friction kevlarpuck/organic face disc. works great.
Re: CLUTCHMASTERS STAGE 3 CARBON KEVLAR DISC WITH ACT XTREME PRESSURE PLATE? (b18sihatch)
did you improve the clamping load on the disc? or the entire clutch setup? having a better pressure plate than a heavy duty had to imporve sumthing, other than a tighter pedal feel
wilntegra
07-16-2005 06:42 AM
