Acura RDX Turbo Motor Cut out pic....
Old Apr 12, 2006 | 08:29 AM
VisualAutoMotoring's Avatar
Default Acura RDX Turbo Motor Cut out pic....
I wonder if this is gonna be the new motor to be had soon?
Old Apr 12, 2006 | 08:36 AM
Soccerking3000's Avatar
Default Re: Acura RDX Turbo Motor Cut out pic.... (Hybrid-Performance.com)
whats the size of the turbo it has, i'm assuming something extremely small at higher psi?
Old Apr 12, 2006 | 08:39 AM
Mase's Avatar
Default Re: Acura RDX Turbo Motor Cut out pic.... (Soccerking3000)
cool pic...
is that a MAF i see? finally see a maf on a honda
Old Apr 12, 2006 | 09:29 AM
B20C1T's Avatar
Default Re: Acura RDX Turbo Motor Cut out pic.... (Mase)
i heard Honda was working on a turbo diesel for their suv's and truck.
Old Apr 12, 2006 | 09:33 AM
ZacCarter's Avatar
MAF is on the K20Z1, I think.
Old Apr 12, 2006 | 09:35 AM
Westrock2000's Avatar
Default Re: Acura RDX Turbo Motor Cut out pic.... (B20C1T)
I saw the prototype at the Dallas Auto Show. Pretty cool looking and not too terribly big. It just said 2.4L turbo (I think it said 2.4L). Whats the rest of the specs, like power and torque wise? Is it a K motor?
The fact of the matter is that it will probably still be cheaper to turbo charge a K20 than buying one of these anytime soon.
That thing on the very bottom, is that for an AWD system?
Old Apr 12, 2006 | 09:37 AM
ZacCarter's Avatar
Default Re: Acura RDX Turbo Motor Cut out pic.... (Westrock2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Westrock2000 &raquo;</TD></TR><TR><TD CLASS="quote">
That thing on the very bottom, is that for an AWD system?</TD></TR></TABLE>
Yea goes to the rea diff.
Old Apr 12, 2006 | 09:45 AM
lightcrx's Avatar
looks so cheap and flimsy
-joseph
Old Apr 12, 2006 | 09:48 AM
ZacCarter's Avatar
Default Re: (lightcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightcrx &raquo;</TD></TR><TR><TD CLASS="quote">looks so cheap and flimsy
-joseph</TD></TR></TABLE>
How so? To my understanding this is based on the k-series?
Old Apr 12, 2006 | 09:53 AM
xci_ed6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">cool pic...
is that a MAF i see? finally see a maf on a honda</TD></TR></TABLE>
Acura Vigor had a MAFs.
Old Apr 12, 2006 | 09:56 AM
fknfast's Avatar
Default Re: Acura RDX Turbo Motor Cut out pic.... (krustindumm)
240hp and 260tq
i think i found a supra killer
Old Apr 12, 2006 | 10:36 AM
Chris99SI's Avatar
Default Re: Acura RDX Turbo Motor Cut out pic.... (fknfast)
Cast iron block?
Old Apr 12, 2006 | 11:17 AM
nsxmatt's Avatar
Default Re: Acura RDX Turbo Motor Cut out pic.... (ZacCarter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZacCarter &raquo;</TD></TR><TR><TD CLASS="quote">MAF is on the K20Z1, I think.</TD></TR></TABLE>
Both Maf and Map are on the new Civics the base and the new Si.
Old Apr 12, 2006 | 12:09 PM
91dxcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20C1T &raquo;</TD></TR><TR><TD CLASS="quote">i heard Honda was working on a turbo diesel for their suv's and truck. </TD></TR></TABLE>
I heard this as well, GM is supposively helping them design it because Honda helped design the motor in the 04+ Saturn Vue, etc..
Old Apr 12, 2006 | 12:12 PM
liam821's Avatar
25 Year Member
Default Re: Acura RDX Turbo Motor Cut out pic.... (91dxcrx)
I dont think that thing will fit under the hood in a eg/dc/ek without moving the intercooler.
liam
Old Apr 12, 2006 | 12:21 PM
rudebwoy's Avatar
I the transmission is gonna be a problem fitting this motor in a civic, unless a b series tranny will fit
Old Apr 12, 2006 | 12:30 PM
black98gsr-t's Avatar
it could be a maf but it looks like a gm throttle body (throttle by wire) crappy electronics..
Old Apr 12, 2006 | 12:51 PM
lightcrx's Avatar
Default Re: (ZacCarter)
maby its the pic but it loks like it came from a model car ;x like a 1:24 etc
-joseph
Old Apr 12, 2006 | 01:34 PM
tegasaurus's Avatar
i would assume its a turbo diesel for the ridgline (the rear diff send off makes me think 4x4 too). I've heard a lot of talk about that. But why in God's name would they run that tiny *** little top mount on a turbo diesel truck?
Old Apr 12, 2006 | 01:56 PM
nitrofish420's Avatar
Default Re: Acura RDX Turbo Motor Cut out pic.... (tegasaurus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">i would assume its a turbo diesel for the ridgline (the rear diff send off makes me think 4x4 too). I've heard a lot of talk about that. But why in God's name would they run that tiny *** little top mount on a turbo diesel truck? </TD></TR></TABLE>
As stated, it's the turbo K24 for the new Acura RDX.
Old Apr 12, 2006 | 02:24 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Re: Acura RDX Turbo Motor Cut out pic.... (nitrofish420)
I read about this in a european magazine a month or so back. They said it was a k23 with a variable veign turbo running 12-14psi. I dont know how acurate that is...but thats what the magazine said.
Look how they have the cat in the stock downpipe. It just looks restrictive as hell. Ill bet an aftermarket dp is gonna do wonders for that thing.
I also read that the head casting is the same as the k20 that was in the ep SI. So you could prolly use an IM and TB off any other k20 and make mad power with a front mount IC.
BTW-If the veigns on the turbo are controlled by the ecu then youll prolly be able to adjust the trim of the turbo with hondata or any other ems
Old Apr 12, 2006 | 02:25 PM
nsxmatt's Avatar
Default Re: (rudebwoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudebwoy &raquo;</TD></TR><TR><TD CLASS="quote">I the transmission is gonna be a problem fitting this motor in a civic, unless a b series tranny will fit</TD></TR></TABLE>
Or maybe a regular K series 2wd tranny?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black98gsr-t &raquo;</TD></TR><TR><TD CLASS="quote">it could be a maf but it looks like a gm throttle body (throttle by wire) crappy electronics..</TD></TR></TABLE>
They all have drive by wire now, including the SI and other models. Plus the maf, and map.
Old Apr 12, 2006 | 02:37 PM
eightvalver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91dxcrx &raquo;</TD></TR><TR><TD CLASS="quote">I heard this as well, GM is supposively helping them design it because Honda helped design the motor in the 04+ Saturn Vue, etc..</TD></TR></TABLE>
Oh so GM needs to give pointers and tips to Honda
Old Apr 12, 2006 | 02:44 PM
turbosi03's Avatar
Default Re: (nsxmatt)
hehe... man I wish I could say something, not about to get fired though
some of you have real info, others are way off
It's not a regular AWD system either...
I can't wait to see this thing in the hands of the aftermarket world
khoalie's Avatar
Default Re: Acura RDX Turbo Motor Cut out pic.... (eightvalver)
to my understanding, honda traded the j35 found in the vue for a small displacement turbo diesel motor for european market civics
