Acura RDX Turbo Motor Cut out pic....
Re: Acura RDX Turbo Motor Cut out pic.... (Hybrid-Performance.com)
whats the size of the turbo it has, i'm assuming something extremely small at higher psi?
Re: Acura RDX Turbo Motor Cut out pic.... (B20C1T)
I saw the prototype at the Dallas Auto Show. Pretty cool looking and not too terribly big. It just said 2.4L turbo (I think it said 2.4L). Whats the rest of the specs, like power and torque wise? Is it a K motor?
The fact of the matter is that it will probably still be cheaper to turbo charge a K20 than buying one of these anytime soon.
That thing on the very bottom, is that for an AWD system?
Re: Acura RDX Turbo Motor Cut out pic.... (Westrock2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Westrock2000 »</TD></TR><TR><TD CLASS="quote">
That thing on the very bottom, is that for an AWD system?</TD></TR></TABLE>
Yea goes to the rea diff.
Re: (lightcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightcrx »</TD></TR><TR><TD CLASS="quote">looks so cheap and flimsy
-joseph</TD></TR></TABLE>
How so? To my understanding this is based on the k-series?
Re: Acura RDX Turbo Motor Cut out pic.... (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase »</TD></TR><TR><TD CLASS="quote">cool pic...
is that a MAF i see? finally see a maf on a honda</TD></TR></TABLE>
Acura Vigor had a MAFs.
Re: Acura RDX Turbo Motor Cut out pic.... (ZacCarter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZacCarter »</TD></TR><TR><TD CLASS="quote">MAF is on the K20Z1, I think.</TD></TR></TABLE>
Both Maf and Map are on the new Civics the base and the new Si.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20C1T »</TD></TR><TR><TD CLASS="quote">i heard Honda was working on a turbo diesel for their suv's and truck. </TD></TR></TABLE>
I heard this as well, GM is supposively helping them design it because Honda helped design the motor in the 04+ Saturn Vue, etc..
i would assume its a turbo diesel for the ridgline (the rear diff send off makes me think 4x4 too). I've heard a lot of talk about that. But why in God's name would they run that tiny *** little top mount on a turbo diesel truck?
Re: Acura RDX Turbo Motor Cut out pic.... (tegasaurus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus »</TD></TR><TR><TD CLASS="quote">i would assume its a turbo diesel for the ridgline (the rear diff send off makes me think 4x4 too). I've heard a lot of talk about that. But why in God's name would they run that tiny *** little top mount on a turbo diesel truck? </TD></TR></TABLE>
As stated, it's the turbo K24 for the new Acura RDX.
Honda-Tech Double Platinum Member
Re: Acura RDX Turbo Motor Cut out pic.... (nitrofish420)
I read about this in a european magazine a month or so back. They said it was a k23 with a variable veign turbo running 12-14psi. I dont know how acurate that is...but thats what the magazine said.
Look how they have the cat in the stock downpipe. It just looks restrictive as hell. Ill bet an aftermarket dp is gonna do wonders for that thing.
I also read that the head casting is the same as the k20 that was in the ep SI. So you could prolly use an IM and TB off any other k20 and make mad power with a front mount IC.
BTW-If the veigns on the turbo are controlled by the ecu then youll prolly be able to adjust the trim of the turbo with hondata or any other ems
Re: (rudebwoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudebwoy »</TD></TR><TR><TD CLASS="quote">I the transmission is gonna be a problem fitting this motor in a civic, unless a b series tranny will fit</TD></TR></TABLE>
Or maybe a regular K series 2wd tranny?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black98gsr-t »</TD></TR><TR><TD CLASS="quote">it could be a maf but it looks like a gm throttle body (throttle by wire) crappy electronics..</TD></TR></TABLE>
They all have drive by wire now, including the SI and other models. Plus the maf, and map.
Re: Acura RDX Turbo Motor Cut out pic.... (91dxcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91dxcrx »</TD></TR><TR><TD CLASS="quote">I heard this as well, GM is supposively helping them design it because Honda helped design the motor in the 04+ Saturn Vue, etc..</TD></TR></TABLE>
Oh so GM needs to give pointers and tips to Honda
Re: (nsxmatt)
hehe... man I wish I could say something, not about to get fired though
some of you have real info, others are way off
It's not a regular AWD system either...
I can't wait to see this thing in the hands of the aftermarket world
Re: Acura RDX Turbo Motor Cut out pic.... (eightvalver)
to my understanding, honda traded the j35 found in the vue for a small displacement turbo diesel motor for european market civics
