Axles breaking
Old Apr 12, 2006 | 08:21 AM
Jesterian's Avatar
Default Axles breaking
Alright, I've got a b16 in my 90 hatch. Originally with the swap, I used the axles that hmotors sent me. Then I started noticing something moving around at the right front area of the car, kind of a jiggling if I hit a bump or took it out of gear. I also noticed that if I hit any type of bump on the right side, it hit really hard and made a loud knock. Shortly after, I noticed that when I put the car into gear there was a slight lag before I actually got power to the wheels.
After I replaced the axles, everything seemed fine. Now it's doing it again. What could be causing that jiggling sensation and my axles to be destroyed yet again?
Could this be a bad rack end bushing, or bad tie rod ends?
Modified by Jesterian at 10:43 AM 4/24/2006
Old Apr 12, 2006 | 08:48 AM
strictlyimport's Avatar
Default Re: Axles breaking (Jesterian)
did you remove the dust ring on the inside of your hubs? if you didn't, the axles won't sit properly which is causing them to break. The dust ring is easy to get out, just use a small flat head screwdriver to get it out.
Old Apr 12, 2006 | 09:07 AM
red_EF9Si's Avatar
the axles you got from HMO are most likely Sir axles. Did they come with the intermediate shaft as well? When you replaced the axles, did you have them rebuilt or used them as cores? Which axles are you using now? Sounds to me like there's a fitment issue. Either too short or too long.
Old Apr 12, 2006 | 09:56 AM
bdubblu's Avatar
Strictlyimport is right about the dust rings! It happened to me as well. The dust ring is press fitted into the back of the hub, but might come off, or fall off, with the axle. Use 90-91 LS axles and you'll be fine.
Brian
Old Apr 24, 2006 | 09:42 AM
Jesterian's Avatar
Default Re: Axles breaking (bdubblu)
Anyone know what could be causing this loud knock if I hit a bump? I know it has to be connected to my axles breaking over and over.
Old Apr 24, 2006 | 10:07 AM
Jesterian's Avatar
Bump, I really need some help on this. It's been a problem since I first had the motor swapped.
Old Apr 25, 2006 | 09:51 AM
Jesterian's Avatar
Bump, no ideas from anyone?
Old Apr 25, 2006 | 10:30 AM
jdmcrx90's Avatar
Default Re: (red_EF9Si)
When i removed my dust ring, and tighented my axels my wheel would not spin and i have a gsr in my crx
Old Apr 25, 2006 | 11:34 AM
Like I have stated in a previous post, did you remove the dust ring? If you didn't, that is why your axles are breaking and moving around. I just did this swap 2 weeks ago and have no problems what so ever with my axles. Did you put them on the right side? I'm not saying your dumb or anything, but there is only a little difference in the size.
If you haven't popped out the dust rings, do so or you will be buying axles quite often.
Old Apr 25, 2006 | 02:42 PM
looxs's Avatar
Default Re: Axles breaking (strictlyimport)
I've been asking around too and all i can say is the removal of the dust ring and are you using the correct half shaft?
Old Apr 25, 2006 | 04:37 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strictlyimport &raquo;</TD></TR><TR><TD CLASS="quote">If you haven't popped out the dust rings, do so or you will be buying axles quite often.</TD></TR></TABLE>
Old Apr 25, 2006 | 04:52 PM
b16civster's Avatar
Default Re: Axles breaking (Tippyman)
my car does the same thing and it seems to be some sort of bushing in the stearing rack.. there was a writeup on it a week or so about it...
Old May 15, 2006 | 07:43 AM
Jesterian's Avatar
Default Re: Axles breaking (b16crexster)
Can anyone hook me up with a pic of the dust ring I'm supposed to remove? I can't seem to find one.
Old May 15, 2006 | 12:08 PM
jacoop86's Avatar
dust ring:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_EF9Si &raquo;</TD></TR><TR><TD CLASS="quote">the axles you got from HMO are most likely Sir axles. Did they come with the intermediate shaft as well? When you replaced the axles, did you have them rebuilt or used them as cores? Which axles are you using now? Sounds to me like there's a fitment issue. Either too short or too long.</TD></TR></TABLE>
like he says, make sure you use the right intermediate shaft with those axles. What intermediate shaft are you using? if you dont know the code, and it came with your engine and tranny, what tranny are you using?
aj_scribble
Apr 24, 2008 06:39 PM
the_rex
Mar 23, 2008 07:44 AM
IntegR
May 7, 2006 03:41 PM
MHhonda99
May 6, 2002 07:42 AM
