Axle Compatibility? DA - DC?
Old Apr 12, 2006 | 03:25 AM
TurboFC3C's Avatar
Default Axle Compatibility? DA - DC?
I own a 91 Integra w/ the stock motor and stock tranny. I needed to replace my driver's side axle and sourced another axle from a 93 GS-R. I know it has the ABS ring deal on it, but the spline doesn't match up to mine.
I took a pic of the GS-R spline, and the "ridges" don't go all the way down like my stock LS one, therefore, it won't go in all the way into my transmission.
So my question is this: Am I only to use a 90-91 Integra axle? or is it more like 90-93 integra LS one? Do 94-01 LS axles work?
I also have a 92-93 GS-R B17 transmission on the side, and was wondering if my current passenger side axle will work w/ the GS-R one. Please Help, I feel lost in this subject!!! I can provide pix if need be.
--David--
Old Apr 12, 2006 | 09:28 AM
TurboFC3C's Avatar
please help!
Old Apr 12, 2006 | 10:38 AM
SlammedDC2teg's Avatar
Default Re: (TurboFC3C)
GSR axles are tottaly diffrent from LS, Just get a 90-93ls, gs, rs axle and you will be fine.
Old Apr 12, 2006 | 11:19 AM
TurboFC3C's Avatar
so if i put in my GS-R tranny, this new axle and the passenger side LS one will work?
Old Apr 12, 2006 | 09:26 PM
TurboFC3C's Avatar
This new axle I got fits perfectly into the GS-R tranny I have on the side. So I just need to know if the 91 LS passenger side axle will work w/ the GS-R one.
Old Apr 12, 2006 | 09:36 PM
watsvtecEK's Avatar
noo, the 90-91 tyranny's are different from the 92-93. u need the axle(s) form a 90-91 integra tranny. The gsr and ls tranny for 92-93 are the same except different gears...
edit.. Put the gsr tranny in!!
Old Apr 12, 2006 | 09:47 PM
TheCheeseWedge's Avatar
all manual integra 90-01 are the same. one just has an abs ring and one doesnt with the exception of the jdm honda integra type r. you probably have the wrong side lol
Old Apr 12, 2006 | 10:09 PM
jgalaz1's Avatar
Default Re: (TheCheeseWedge)
The driver's side axles are the same from 90-93. 94-01 use a different half shaft. My guess would be that you have the wrong axle. The passenger side axle is the same from 90-01. hope this helps
Old Apr 13, 2006 | 01:28 AM
TurboFC3C's Avatar
Whoa, so what I see here is one person saying that 90-91's are different than 92-93's.
One other person saying that 90-01's are the same.
And another person saying that 90-93's are the same but different than the 94-01's.
So what is it??
Old Apr 13, 2006 | 03:30 AM
crxnj's Avatar
Default Re: Axle Compatibility? DA - DC? (TurboFC3C)
In this country all 90-01 B-series passenger side axles are the same/interchangeable..
For the driver side, 90-93 integra axles are different then 94-01..90-93 integra axle has male joint and the 90-93 integra halfshaft is female.....Where as the 94-01 integra axle has a female inner joint and the 94-01 integra halfshaft is male..
And by the way,, the 94-01 integra,99-00civic si,and del b16 axles are all the same ****..
Old Apr 13, 2006 | 09:36 AM
TurboFC3C's Avatar
So then why does the 93 GS-R axle work with the B17 Tranny and not my 91 LS tranny? If you say that all the 90-93 drivers axles are the same?
Old Apr 13, 2006 | 10:22 AM
RHDintegXsi's Avatar
from my own experience 90-93 drivers axles are the same. the picture you have posted is a passenger side axle.
drivers=full spline
pass=half spline
Old Apr 13, 2006 | 12:00 PM
TurboFC3C's Avatar
Can anyone else confirm that I do indeed have the passenger side axle?
Old Apr 13, 2006 | 12:26 PM
projectTeG's Avatar
Default Re: (jgalaz1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jgalaz1 &raquo;</TD></TR><TR><TD CLASS="quote">The driver's side axles are the same from 90-93. 94-01 use a different half shaft. My guess would be that you have the wrong axle. The passenger side axle is the same from 90-01. hope this helps</TD></TR></TABLE>
this guy is right...theres alot of half truths here.
Old Apr 13, 2006 | 07:46 PM
Default Re: Axle Compatibility? DA - DC? (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">In this country all 90-01 B-series passenger side axles are the same/interchangeable..
i was 1/2 wrong lol listen to this guy
Old Apr 13, 2006 | 09:54 PM
912's Avatar
912
Default Re: Axle Compatibility? DA - DC? (TheCheeseWedge)
what if i swaped out the half shaft on my da to a dc2 half shaft will i be able to run 94-01 driver side axle
Old Apr 13, 2006 | 10:06 PM
crxnj's Avatar
Default Re: Axle Compatibility? DA - DC? (912)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 912 &raquo;</TD></TR><TR><TD CLASS="quote">what if i swaped out the half shaft on my da to a dc2 half shaft will i be able to run 94-01 driver side axle</TD></TR></TABLE>
Yup..
Old Apr 13, 2006 | 10:47 PM
Mr. Tech's Avatar
90-93 G2 Integra Axles are a tad shorter than the newer ones 94-01
Old Apr 13, 2006 | 10:58 PM
912's Avatar
912
Default Re: Axle Compatibility? DA - DC? (RISKTuner)
so it's not possible to swap the driver side da axle setup with one from dc2, i'm talkin axle and half shaft
Old Apr 13, 2006 | 11:02 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RISKTuner &raquo;</TD></TR><TR><TD CLASS="quote">90-93 G2 Integra Axles are a tad shorter than the newer ones 94-01</TD></TR></TABLE>
On the driverside yes they are different,,Not sure about the length but they have different inner joints,,one is female and one is male.......But passenger side they are the same ****..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 912 &raquo;</TD></TR><TR><TD CLASS="quote">so it's not possible to swap the driver side da axle setup with one from dc2, i'm talkin axle and half shaft</TD></TR></TABLE>
Yes you can do that..90-93 integra halfshaft with 90-93 integra axle.....or 94-01 integra haflshaft with 94-01 integra axle..Both ways will work..Just have to get the axle that matches the halfshaft..
Old Apr 13, 2006 | 11:46 PM
912's Avatar
912
thanks yes i have dc2 axle and half shaft, i just got a da and is has driverside axle problem instead of buying new oe i could just swap in my dc2 half shaft and axle, thanks
Old Apr 14, 2006 | 05:58 PM
Mr. Tech's Avatar
Not to start a heated debate or anything, i used to work at autozone the part numbers for the passenger sides are different. and i've putten a few g2 passenger side axles into a g3 with no problem but the cars were all slammed so it compensated for the axle length. When we raised the car a little bit it started toclick. I put a g2 axle in a non lowered g3 once and it was clicking like crazy til i lowered it.
StolenTeg
Jun 1, 2009 12:23 PM
iBear
Oct 24, 2004 03:11 PM
98r410
Mar 17, 2003 12:08 PM
Dorikamu
Nov 5, 2002 09:44 AM
