REAL quick question for all you know it alls
Old Apr 11, 2006 | 10:31 PM
CBEengineering's Avatar
Default REAL quick question for all you know it alls
an dc2/4 torque mount will/will not interchange with eg,ej torque mount either side?
Old Apr 11, 2006 | 10:44 PM
Default Re: REAL quick question for all you know it alls (CBEengineering)
damn this was supposed to be real quick you guys are falling off
bet if i asked how to get my 159$ ebay body kit to fit someone would have answered me in 30 sec.
Old Apr 11, 2006 | 10:47 PM
japan4racing's Avatar
i couldnt use mine from my swap. if i remember right, the civic ones would not bolt onto the gsr motor. however i think you can use the b series ones with the civic rubber peices and it may work. i dont have any on my car at all..but i also have hasport solid mounts so the motor does not mave anyways
Old Apr 11, 2006 | 10:48 PM
and to answer your question about the body kit...throw it away and put the stock stuff back on....it will look so much better that way
Old Apr 11, 2006 | 10:50 PM
Default Re: (japan4racing)
the body kit was a joke lol
and the mounts im talking about are the rubber ones not the physical mounts but the d shaped thingy (technical term)
Old Apr 11, 2006 | 11:16 PM
Default Re: (CBEengineering)
up before i go to bed dammit Quick. adj. used to describe someone that answers questions promptly.
Old Apr 12, 2006 | 12:47 AM
_Bug_'s Avatar
Are you talking about the inserts?
Old Apr 12, 2006 | 06:32 AM
miahmouse's Avatar
I don't think the mounts are interchangable (the ones that bolt to the chassis)
Old Apr 12, 2006 | 06:11 PM
Default Re: (JDM_Bug)
no the actual mounts
Old Apr 12, 2006 | 07:31 PM
Echo7847's Avatar
A/c bracket and front trans bracket must be integra or must be civic (not interchangeable). The rubber mounts that bolt into the frame are diff part #'s but try it and see if it works.
Old Apr 12, 2006 | 07:36 PM
Default Re: (Echo7847)
i know about the brackets ive done the swap a million times but always used the civic but i found an upgrade MMkit for an integra and jus was wonderinghttp://cgi.ebay.com/ebaymotors...es_IT
Luke G.
Aug 25, 2009 01:56 PM
ten2doyle102
Aug 6, 2008 05:11 AM
lurkin' eg
Nov 30, 2007 03:48 PM
Civic*B16A3*Eg
May 4, 2007 04:38 PM
[626]95-GSR
Nov 20, 2005 09:15 AM
