noise suppresion for the EF
are there methods of suppressing the road and engine noise, like spray on linings or padding? I have a Type R swap, so I get quite a bit of noise, even outside of VTEC. I only want to hear my engine when I am pushing it.
Are you using aftermarket mounts, like HASports?
They transmit a bunch of noise into the car.
A friend has a 01 Civic with an 00 ITR swap. Those Civics can use all OEM mounts to hold a B engine. Her car is stock quiet. It makes me sick. It is sooo nice.
The best way to do that with our cars would be to do an old school style swap with DA mounts welded in.
Outside of that, I'd like to try an EF8 intake system instead of a CAI.
Mmm, it's less the revving and more the road noise. I can drive around revving as high as I do on the highway and as long as I'm not going over like 65-70ish, the noise isn't too bad.
yeah, I am planning on installing sound insulators on the floor below the carpet and on the door panels... Try any sound insulator mat.
Running with the stock airbox versus a cold air intake doesn't seem to make much difference for noise
For my type-R swap, I found that the exhaust was really noisy before I installed a cat. It's still loud, but manageable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jesterian »</TD></TR><TR><TD CLASS="quote">So the best idea would be to spray down a rubberized undercoating, then lay dynomat?</TD></TR></TABLE>
that spray on rubberized coating works wonders
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pee Wee »</TD></TR><TR><TD CLASS="quote">that spray on rubberized coating works wonders</TD></TR></TABLE>
I have a couple bottles. Just strip my interior, sand the area I plan to rubberize, then apply?
What do you guys expect, our ef's are one of the lightest cars on the road, especailly after we are done with them. For 1800-2100lbs, the cars don't have the heavy sound dampening material. A fully gutted track ef is really loud, but in my ef it some times suchs, and other times I love it. It's just part of owning an ef, and for me a crx
It's another reason why ef's are so light in comparison to other cars on the road, less sound dampening material equals less weight. And by the way, dynomat is really heavy for it's size, and it takes a lot of it to work, and it's expensive. Rubberizing undercoating is lighter, more flexible, water proof, sound dampens, and is alot less expensive. So if you need to dampen sound, and waterproof, rubberizing spray works great.
