Symptoms of bad iacv
Old Apr 11, 2006 | 08:13 PM
Eaglekper0046's Avatar
Default Symptoms of bad iacv
What are the symptoms? I dont have a check engine light. Vtec doesnt engage, it has plenty of oil, water temp is good.. I did a ecu swap on my ek hatch mini me. I swap the wire on the ecu b6-b23.
Old Apr 11, 2006 | 08:17 PM
SVOboy's Avatar
Take the iacv and spray fuel injection system cleaner in there and clean it the hell out to see if it makes whatev better.
Old Apr 11, 2006 | 10:17 PM
Default Re: (SVOboy)
Any other Ideas?
Old Apr 11, 2006 | 10:25 PM
ccjustin's Avatar
if its a bad IACV the idle will surge as the ecu tries to correct what the IACV should be doing. when you drive the car, load on the engine, the surge goes away
Alicali
Sep 10, 2017 09:40 AM
civicguy167
15
Dec 3, 2013 08:45 PM
hifi_civic
Oct 5, 2011 11:29 AM
TypeRMOBBiN209
May 28, 2009 03:34 PM
Dancing is Forbidden
12
Mar 7, 2004 08:29 PM
