Where do I start for NOS setup?
Old Apr 11, 2006 | 07:17 PM
b16a2EBP's Avatar
Default Where do I start for NOS setup?
Where do I start? What's the difference between dry and wet? What is better? I have an LS with AEM SRI, Header, 2.5inch catback, NGK Sparks and wires. Thanks.
Old Apr 11, 2006 | 07:39 PM
Vi3tboy's Avatar
dry setup you just shoot it into your intake.
wet- it mixes with fuel before entering your vehicle.
first off you might want different plugs. (colder plugs)
you def will need a new clutch flywheel after a bit of nitrous use.
how much are you looking to run?
Old Apr 11, 2006 | 07:54 PM
Azn Kenny's Avatar
Here's what I did:
-NGK BKR7E spark plugs (2 heat ranges colder than stock)
-B&M adjustable fuel pressure regulator (tp bump up the fuel)
-retard timing by 2 degrees (for every 50 shot)
Dry kit's are easy to install and are simple to use, good for beginners but don't go over a 75 shot.
Wet will give you more power and is safer (less chance of detonation).
Only spray at WOT over 2500k and don't hit redline!
Old Apr 11, 2006 | 09:31 PM
tougsr's Avatar
Default Re: Where do I start for NOS setup? (b16a2EBP)
Old Apr 12, 2006 | 11:49 AM
rgaray's Avatar
I don't mean to hi-jack the thread, but has anyone thought of doing both wet and dry?
Old Apr 12, 2006 | 12:00 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (rgaray)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rgaray &raquo;</TD></TR><TR><TD CLASS="quote">I don't mean to hi-jack the thread, but has anyone thought of doing both wet and dry?</TD></TR></TABLE>
If you fully understand the difference between wet, and dry,
That question gets a little harder to answer, also makes less sense.
Old Apr 12, 2006 | 04:26 PM
s2kdre's Avatar
Default Re: (FlatBlackTeg)
how much power do u want? on an ls u can easly do a 75 wet or even a 100shot if used safely, its a low compression motor.
Old Apr 12, 2006 | 04:27 PM
s2kdre's Avatar
Default Re: (jdmhonda)
the best kit would be from nitrous express, its a direct port setup.
95greenlude
May 2, 2007 02:02 PM
tmekjian
Jun 11, 2003 11:35 AM
tmekjian
May 1, 2003 09:53 AM
integra1884
Jan 6, 2003 07:26 PM
DaNish
Oct 18, 2001 05:40 PM
