CHECK ENGINE LIGHT KEEPS COMING ON (2000 EX)
Old Apr 11, 2006 | 06:17 PM
trz103's Avatar
Default CHECK ENGINE LIGHT KEEPS COMING ON (2000 EX)
My check engine light first came on about 2 weeks ago, took it in and had the codes reset and it went away. came back on this weekend and took it back in for service, was told it was the oxygen sensor so they replaced it. light came on again..was told they replaced the wrong oxygen sensor so they replaced the other one. car was fine on way to work today, light came back on during drive home. anyone have any clue whats going on here??? i guess it might be easier if i knew which code they were getting.
Old Apr 11, 2006 | 06:25 PM
mycargov6room's Avatar
does the light come on after you fill-up? if so, you could be not tightening the gas cap enough.
Here a DIY for checking your check engine light
http://www.v6performance.net/f...41989
Old Apr 11, 2006 | 06:35 PM
trz103's Avatar
Default Re: (mycargov6room)
well, i do think i've been tightening it well. i was informed of this so when i got home tonight i did unscrew and re-tighten the gas cap to make sure. when i opened it i heard a fair amount of air pressure released? is that normal? i probably sound like an idiot but I rarely pay attention to this kind of stuff. i wish i knew exactly how to do jump the terminal explained in that link so i can find out the code myself. apparently it has to be one of the codes involving an O2 sensor
Old Apr 11, 2006 | 06:43 PM
Ross 2.0's Avatar
In a Junkyard near you.
Take it to a parts store that will pull the codes for free. Or check your recipt and post the codes on here it will be "P____" like P1456.
Tell us exactally and we can help you out better
Old Apr 11, 2006 | 06:57 PM
trz103's Avatar
Default Re: CHECK ENGINE LIGHT KEEPS COMING ON (trz103)
Ok just found the receipts..from the first trip the code listed is P1149 on this latest receipt it does not list a code but i guess thats the same deal
Old Apr 11, 2006 | 07:06 PM
Ross 2.0's Avatar
Honda has a service bulliten out for this problem. You need to replace your ECM (engine control module). The O2 sensors were probably ok. You current computer is setting false codes.
Old Apr 11, 2006 | 07:11 PM
trz103's Avatar
Default Re: (MooGoCow3)
so essentially i spent $300 for the O2 sensor with labor and can now expect about $800 to replace the ECM? wonderful
Old Apr 11, 2006 | 07:33 PM
i think this is it
http://www.98exl.com/tsb/CG/01...9.pdf
I would make sure before spending the $$
Old Apr 11, 2006 | 07:41 PM
trz103's Avatar
what are the odds i can get the oxygen sensor taken out and refunded since its clearly not the problem?
Old Apr 11, 2006 | 07:44 PM
accord-pro's Avatar
Default Re: (trz103)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trz103 &raquo;</TD></TR><TR><TD CLASS="quote">so essentially i spent $300 for the O2 sensor with labor and can now expect about $800 to replace the ECM? wonderful</TD></TR></TABLE>
moogo is correct ( service bulletin 01-031 ,,) it applies to all 98-00 accords
if code p1149 ,, replace ecm..
was this a dealership ??
get your money back. they did not fix your problem , do not get upset.....kindly talk to the store manager and mention the bulletin and why they did not follow precedures to replace the ecu,, and ask him to put the money that you spent toward the ecm,, tell him that it was their mis diagnose that cost you money you should not have spent in the first place .. if this is a reputable shop i am sure he will help you out..
if he does not want to help,, call the better business bureau in your city..
Modified by accord-pro at 8:54 PM 4/11/2006
angryk
Honda Civic (2001 - 2005)
Dec 28, 2007 11:53 AM
B18Redline
Apr 7, 2004 08:01 AM
Preludegirl
Dec 3, 2003 08:14 AM
Dan
Nov 19, 2002 10:18 PM
