2000 jdm civic si problems and concerns help me out
Old Apr 11, 2006 | 05:56 PM
jugodmyko's Avatar
Default 2000 jdm civic si problems and concerns help me out
Got a skunk2 intake manifold installed and my idel sucks any one know why and how do i fix this?
Got the top fuel power neo it saves gas but didn't notice any power change!
Got skunk2stg2 camshafts in my si and want to know which tunning device is best? i have dc 41 header sun hyper voltage system aem cai w bypass skunk2 manifold skunk throttle body fidanza flywheel apexi ni cat back ixradium sparkplug wires.
i keep putting water in my car and the next day its empty any one know why?
check out my ride at hondashowoff.com its a blue si just posted it up this month
Help me out!!! Miguel A.
Old Apr 11, 2006 | 06:33 PM
civicsi_guy's Avatar
what do you mean it sucks that could mean a lot of things stalling, surging, sputtering, high idle ??????
Old Apr 11, 2006 | 06:51 PM
intevic_dx's Avatar
could be idling like a car with cams.
Old Apr 11, 2006 | 06:55 PM
b16a2_v-tech's Avatar
69.212.15.27
Default Re: 2000 jdm civic si problems and concerns help me out (jugodmyko)
never heard of b4
Old Apr 11, 2006 | 07:09 PM
professor poon's Avatar
what is a 2000 jdm civic si?
Old Apr 11, 2006 | 07:14 PM
KoLRaNcH's Avatar
Default Re: (professor poon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by professor poon &raquo;</TD></TR><TR><TD CLASS="quote">what is a 2000 jdm civic si?</TD></TR></TABLE>
I don't know either, supposedly this kid has the one and only jdm civic si.
Old Apr 11, 2006 | 07:36 PM
E46Kid's Avatar
Default Re: (KoLRaNcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KoLRaNcH &raquo;</TD></TR><TR><TD CLASS="quote">
I don't know either, supposedly this kid has the one and only jdm civic si. </TD></TR></TABLE>
lol
Old Apr 11, 2006 | 08:00 PM
posite's Avatar
Old Apr 11, 2006 | 08:54 PM
Out of every
Default Re: (posite)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jugodmyko &raquo;</TD></TR><TR><TD CLASS="quote">Got a skunk2 intake manifold installed and my idel sucks any one know why and how do i fix this?
Help me out!!! Miguel A.</TD></TR></TABLE>
okay im going to help you out...
1. use commas.. serious
2.idle could be lots of things:
vac hose leak
bad gasket maybe youdidnt remove all of the old one or didnt change it
fitv needs to be cleaned but you have a 2000 jdm si so i dont think you have one of those
your iacv needs to be cleaned (always a prime suspect)
4. i would check the header i mean 41 dc header? thats alot of piping
5.your not supposed to put water in your motor (radiator)
coolant is your friend
haha i like this noob
Old Apr 12, 2006 | 08:49 AM
jugodmyko's Avatar
Ok its not an actual jdm si but hopefully in a few months it will be pretty close check out my ride at hondashowoff.com i just posted it its a blue 2000 si with the advan rg1 wheels. any ways... thanks for the replys
i did change the gaskets i got the hondata im gasket... and for the tb i used the one it came with.. i do have an extra hose around for the manifold but for some reason i dont think its there no where to connect it and i cant find a t hose connecter that fits it. i took it to a shop ctr dynosports in mod. nor cal and all they did was make sure it idels and wont turn off on me.
b4 it wouldnt idle id try turning it on and poof it wouldnt hold the idle. id move the throttle cable and it would idel to high or to low and then would just die. i was online and found some one else w the same problem but no one gave him a solution that worked. any help would b f awsome!!!!
Old Apr 12, 2006 | 12:05 PM
Out of every
have you cleaned the iacv? that usually causes it
Old Apr 12, 2006 | 12:19 PM
jugodmyko's Avatar
Not a mechaniq just a little punk ***... whats a iacv? wheres it at?
Old Apr 12, 2006 | 12:30 PM
1bar_ek's Avatar
Default Re: (jugodmyko)
The iavc (Idle Air Control Valve) regulates idle speed, raising and lowering it as needed. It does this by opening and closing a "trim" valve to allow more or less airflow into the intake manifold when the throttle is closed.
With your skunk2 intake manifold, the iavc should be located right on the back of your im.
Old Apr 12, 2006 | 12:36 PM
Out of every
Default Re: (1bar_ek)
brb i'll post a pic
Old Apr 12, 2006 | 12:43 PM
Out of every
Default Re: (e gee two)
this is what your looking for to be more straight foward.
take that off and there shoud be 2 holes one with a screen and one without. take some carb cleaner and spray in both for about 20 secs each or until youthink its clean. wait for about 1 hour and a half then put it back on the same way you took it off. done gl
Old Apr 12, 2006 | 01:33 PM
jugodmyko's Avatar
Thanks ill try this when i get back to night im going to sac raceway to time my car for the first time
Old Apr 12, 2006 | 03:23 PM
jdmeg9's Avatar
yeah don't worry about fixing it just go time it
Old Apr 12, 2006 | 03:39 PM
chameleon30038's Avatar
Well i can't really help you solve ur probs but i know there is no such thing as a "JDM 2000 Civic Si". Also why are you putting water in your car and not coolant? Water evaportates quicker.
Old Apr 12, 2006 | 03:42 PM
Out of every
Default Re: 2000 jdm civic si problems and concerns help me out (chameleon30038)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chameleon30038 &raquo;</TD></TR><TR><TD CLASS="quote">Well i can't really help you solve ur probs but i know there is no such thing as a "JDM 2000 Civic Si". Also why are you putting water in your car and not coolant? Water evaportates quicker.</TD></TR></TABLE>
okay???? why did you restate what everyone already said??
senseless post
Old Apr 12, 2006 | 04:12 PM
KoLRaNcH's Avatar
Default Re: 2000 jdm civic si problems and concerns help me out (e gee two)
He knows he doesn't have a jdm si. He just put that in his title for some reason, just look a couple post above.
Old Apr 13, 2006 | 10:53 AM
jugodmyko's Avatar
Thanks for all the help cleaning it did help the idel better today i noticed a change. i went to the track but there was a rain delay so i guess i got to wait for next week.
Old Apr 13, 2006 | 11:00 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jugodmyko &raquo;</TD></TR><TR><TD CLASS="quote">Got the top fuel power neo it saves gas but didn't notice any power change!
What? A magnent didn't give you horsepower??? Impossible!
Old Apr 13, 2006 | 11:05 AM
jugodmyko's Avatar
That damm magnent didn't give me horsepower but damm it sure helps on gas!!!
Old Apr 13, 2006 | 01:31 PM
jdmeg9's Avatar
it may be minimal without a good tune. i would worry more about fixing your car
prettyinpinkSI
Apr 4, 2019 08:45 PM
Sil84
13
Sep 19, 2007 11:53 AM
ShowSi2
Mar 16, 2004 05:46 AM
