After adjusting valves
Old Apr 11, 2006 | 05:25 PM
EF9ZC's Avatar
Default After adjusting valves
After you adjust valves are they still supposed to tick. I'm just wondering because i adjusted mine like 1000 miles ago or so. And i had slight misfire tonight when i was driving and im trying to find some stuff that could be wrong. I'm going to pull plugs tomorrow that could be problem being that my o2 sensor is bad i'm probably runnin rich but its been bad for the whole 1000 so i dont think fouled out plugs could be it. Anyways back to my question are valves supposed to tick always or not? This is a z6 on a6 if it matters. TIA
Old Apr 11, 2006 | 08:53 PM
yellowrexsi's Avatar
Default Re: After adjusting valves (EF9ZC)
They shouldn't tick. But almost every honda I have ever heard does. I would change the plugs and the o2 sensor. Fix the problems that you know are wrong. It will make it easier to trouble shoot, problems later.
Old Apr 11, 2006 | 08:57 PM
Jonknee's Avatar
Default Re: After adjusting valves (yellowrexsi)
Hey what did you set your clearance at?
Old Apr 12, 2006 | 07:53 AM
EF9ZC's Avatar
.06 and .08 d16z6
Old Apr 12, 2006 | 07:59 AM
jlicrx's Avatar
Default Re: (EF9ZC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9ZC &raquo;</TD></TR><TR><TD CLASS="quote">.06 and .08 d16z6</TD></TR></TABLE>
D16Z6 valve clearances:
Intake - 0.007-0.009in
Exhaust - 0.009-0.011in
Old Apr 12, 2006 | 08:18 AM
EF9ZC's Avatar
well .008 and .010 cause all i had was the even ones. Guess ill redo them today
Old Apr 12, 2006 | 08:53 AM
SFlCrx's Avatar
make sure you set each cylinder at TDC when you are setting the lash
Old Apr 12, 2006 | 09:03 AM
YasRex's Avatar
Default Re: (SFlCrx)
make sure the engine is dead cold (sitting over night) before you adjust as well
Old Apr 12, 2006 | 12:33 PM
EF9ZC's Avatar
did that and its just supposed to drag a little on the thing right?
Old Apr 12, 2006 | 12:39 PM
EJ1 wilcox's Avatar
Default Re: (EF9ZC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9ZC &raquo;</TD></TR><TR><TD CLASS="quote">well .008 and .010 cause all i had was the even ones. Guess ill redo them today</TD></TR></TABLE>
No need to redo them. You should be fine, that's right in the middle of the range.
I do mine just a little tight. Meaning, .007 and .009, and tight enough so I can barely slide the feeler through without it getting stuck.
But, as long as you are within the range, you should be fine.
Old Apr 12, 2006 | 12:53 PM
EF9ZC's Avatar
That sucks though because that rules that out for being problem for missfiring. Oh well my port flow head be here and i'll get o2 sensor after this weekend then ill get back to you. Just sucks i got to drive hour and half drive to jacksonville hopefully no problems....*knock on wood*
Old Apr 12, 2006 | 02:58 PM
Jonknee's Avatar
Default Re: (EF9ZC)
Good luck dude.
Old Apr 12, 2006 | 03:45 PM
EF9ZC's Avatar
thanks ill let you know sometime next week going to put in zex cam victor manifold and port flow head with supertech valvetrain (via earl) all in one day should be nice gains maybe ill install vafc same time same channel....
1SikEagle
Sep 23, 2009 10:15 AM
Xathine
Aug 8, 2008 11:58 AM
flashedDc5
Oct 10, 2006 05:12 PM
92ehatch
Aug 24, 2006 05:41 AM
