oil pan
how hard wud it be to install a new oil pan i mite be buying a 1992 civic hatch and it needs a new oil pan...i believe the oil pan is already out it just needs to be put in..do i have to take the crank pully off to put it in?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">Pan is just held on by a bunch of 10mm nuts/bolts
Remove them, put on a different pan with a new gasket, put nuts/bolts back on w/ proper tq.
Done.</TD></TR></TABLE>
dam beat me to it
dam beat me to it
u dont 'have to remove the header unless it's really tight against the eingine, most of the time u can slide it above and just pop it on
EDIT:
eh, srike that
too many variables, if the header's a 2 piece, you can detatch the 2 bolts on the 2nd piece to it hangs more, that'll give you clearance if u don't have it, if it can hange, u can detach the hangers at the end of the header, it really depends on what ur looking at, but it's not hard at all, just like he said, a bunch fo 10mm bolts, make sure it's a new gasket, make sure they're the right torque
EDIT:
eh, srike that
you do not have to take the crank pully off....
I know i have next to no exp working on hondas, but I even doubt here you'd have to take the crank pully off, completely illogical
civicSF98
Jul 20, 2009 09:24 AM
Horatio
10
May 3, 2004 01:44 PM
