HELP... misfire cylinder 1-4
okay... my car started this misfire cylinders after i used the seafoam in my motor... i drove it for 2 days straight forgot to changing my oil. i search on this and most people say it might just need to clean the carbouator... (however you spell it) so i pour a bottle of carbouator cleaner into my gas tank. and now it just misfire in cylinder 1 & 3. what do you guyz think i need to do about cylinder 1 & 3? and no O2 sensor code is popping up just the misfire cylinders code. already change cap and rotor for distributor. any help would be good. thanks,.
Modified by poorman's type-r at 6:05 PM 4/11/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poorman’s type-r »</TD></TR><TR><TD CLASS="quote">okay... my car started this misfire cylinders after i used the seafoam in my motor... i drove it for 2 days straight forgot to changing my oil. i search on this and most people say it might just need to clean the carbouator... (however you spell it) so i pour a bottle of carbouator cleaner into my gas tank. and now it just misfire in cylinder 1 & 3. what do you guyz think i need to do about cylinder 1 & 3? and no O2 sensor code is popping up just the misfire cylinders code. already change cap and rotor for distributor. any help would be good. thanks,.
Modified by poorman's type-r at 6:05 PM 4/11/2006</TD></TR></TABLE>
Your fuel injected car does not have a carburetor. Where did you put the seafoam? I suggest a compression test.
i pour the seafoam in the intake, the oil, and gas. all 1/3. car was running fine until 2 days after the seafoam. and can my cat. convertor caused this? or O2 sensors?
the EFI written in your manual, fuel injectors, fuel rails, and the absence of a carberator should have given away the fact that you dnt have one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poorman’s type-r »</TD></TR><TR><TD CLASS="quote">i pour the seafoam in the intake, the oil, and gas. all 1/3. car was running fine until 2 days after the seafoam. and can my cat. convertor caused this? or O2 sensors?</TD></TR></TABLE>
Perhaps some debris broke free in the fuel system, managed to pass the fuel filter, and clogged injectors 1 and 3. Try the compression test. It is cheap and easy. Also, have you looked at you spark plugs? Are 1 and 3 different?
will i check the plug and clean them. all of them were white except the 4th. the 4th was brown. the 3rd one had a little oil on it. all the plug wires are in the right places. the distributor rotor was burn at the tip and i replace it. still misfiring cylinder 1 & 3. before those check up all 4 cylinder was misfiring.
update: just when i change the plugs and reset the ecu. the ECL is off but when the motor is reving to 3k it back fires a lot. can the wires or plugs still be a issue? and i dont know if this causes my motor to misfire but a week ago my heat shield for my cat convertor broke off on the bottom.
Modified by poorman's type-r at 9:02 PM 4/11/2006
Modified by poorman's type-r at 9:07 PM 4/11/2006
Ideal
Oct 18, 2005 02:20 PM
H.A.R.T B18C1EG6
Jul 12, 2005 07:09 AM
[626]95-GSR
Sep 19, 2002 09:26 PM
