code#9 #1 cylinder sensor
I was driving when I just decided to try out the new tires i got. So I gunned it from just 1st to 2nd gear then stopped. Then A CEL popped up. I checked the code its a code 9. I see that its a cylinder sensor and I know its in the distributor. Is it serious where I really have to change the distributor or can I just take the ECU fuse and wipe the code out? help me
Mr. Badwrench
Re: code#9 #1 cylinder sensor (H.A.R.T B18C1EG6)
you may be able to clear it but if it is a failure and comes back on, you will need to investigate. the first thing on a honda diag flow chart, is clear code and drive. if it doesnt come back on, it is aqn intermittent failure.
Re: code#9 #1 cylinder sensor (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">you may be able to clear it but if it is a failure and comes back on, you will need to investigate. the first thing on a honda diag flow chart, is clear code and drive. if it doesnt come back on, it is aqn intermittent failure.</TD></TR></TABLE>
thanx imma try that out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">get a service manual and start trouble shooting unless you have another dizzy to throw at it.</TD></TR></TABLE>
yeah im bout to go and throw another dizzy on and hopefully it will take the code out. What do I do if that doesnt work.
Hey man I sent you an IM and you haven't responded.
I don't want to get my money back...I want the rims I paid for.
All I need you to do is call fedex please and tell them what was in the box when you packaged it and what color was the rims. Provide them with the tracking ID and they will pull up the information and get the order fixed and sent to me.
Don't try to screw or ignore my IM's man...I called your cell and left a message just incase.
Thanks
bart
Thanks
bart
RaIn
04-20-2003 08:05 PM
