88 89-90 91 tail lights......
Old Apr 11, 2006 | 01:24 PM
cr-rex88's Avatar
Default 88 89-90 91 tail lights......
is there way you can make 90-91 tail lights fit on a 88-89 rex without any fabrecating or any major change's?
Old Apr 11, 2006 | 01:27 PM
racingcrx's Avatar
Default Re: 88 89-90 91 tail lights...... (cr-rex88)
you should not have to make and changes. do you?
Old Apr 11, 2006 | 01:55 PM
cr-rex88's Avatar
Default Re: 88 89-90 91 tail lights...... (racingcrx)
well my buddy has a 90 and we tryed putting them on mine cuz i just like those way better (i have an 88 by the way) and they just didnt seem to line up right like they were smaller.
Old Apr 11, 2006 | 04:31 PM
cr-rex88's Avatar
...........bump..........
Old Apr 11, 2006 | 04:38 PM
CRX Toad's Avatar
Huh, that is odd cause I have a 1991 CRX and I have 88 tail lights on mine. They just fell right in. They must have made your car different than everyone elses.
Old Apr 11, 2006 | 05:10 PM
SIXTY's Avatar
Default Re: 88 89-90 91 tail lights...... (CRX Toad)
You should have no problems putting those on, i got an 89 dx and i put on 91 si's, just bolted right up. If they look smaller it might just be the design, the 90-91's have a thick black border around them giving it a thinner look. good luck.
Old Apr 11, 2006 | 05:12 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cr-rex88 &raquo;</TD></TR><TR><TD CLASS="quote">is there way you can make 90-91 tail lights fit on a 88-89 rex without any fabrecating or any major change's?</TD></TR></TABLE>
They are interchangeable. No modifications required.
Old Apr 11, 2006 | 05:24 PM
Pooby88's Avatar
Default Re: 88 89-90 91 tail lights...... (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
They are interchangeable. No modifications required.</TD></TR></TABLE>
x2
I've ownes 2 '88 CRXs and I replaced both taillights with '90-91 style. Bolts in the same as originals.
Old Apr 11, 2006 | 09:11 PM
cr-rex88's Avatar
Default Re: 88 89-90 91 tail lights...... (Pooby88)
wow i dunno maybe im just a tard lol anyways i just got a set and u guys were right they fell right in. thanx guys.
Old Apr 11, 2006 | 09:19 PM
madmanmulligan's Avatar
they should line right up
Old Apr 11, 2006 | 11:04 PM
1point7db2's Avatar
Default Re: 88 89-90 91 tail lights...... (madmanmulligan)
I have an 88' crx Si, when I swapped in tailights from a 91, I had to use the plugs from the 91'.
Old Apr 11, 2006 | 11:22 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: 88 89-90 91 tail lights...... (blownEG93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blownEG93 &raquo;</TD></TR><TR><TD CLASS="quote">I have an 88' crx Si, when I swapped in tailights from a 91, I had to use the plugs from the 91'.</TD></TR></TABLE>
Mines an 89, they fit right in also, but yes, needed the 90-91 style plugs. Maybe your car was in a previous accident, so parts don't fit properly.
Old Apr 12, 2006 | 12:10 AM
FOMULA91's Avatar
Default Re: 88 89-90 91 tail lights...... (Deetz)
My friend has an 88 HF with 90-91 tail light, so it should fit without any problem.
Old Apr 12, 2006 | 03:49 AM
crx_88_si's Avatar
yep 91 tails fit onto 88-89 cars. There was something weird about the wiring.
I cant remember if i used the 88 harness but swapped sides or used the 91 and swapped sides... o well, im pretty sure i had to swap right to left and left to right for some reason.
88SeeOurEx
Nov 5, 2008 12:39 PM
taylor1
Aug 29, 2008 09:46 AM
effinnwackk
Jan 29, 2005 10:22 PM
CrazyModGSR
May 23, 2004 03:34 AM
sir91
Jul 20, 2003 12:03 AM
