Mugen Intake Directions Translated
Old Apr 11, 2006 | 01:04 PM
Trellis's Avatar
Default Mugen Intake Directions Translated
A while back someone posted the Mugen Intake Directions translated...need help locating it.....
Also I got about 12" of double sided tape with my kit? the tape in the bottom right of the pic....And its not the tape that is used for connections from in the fender that metal tape..this is regular double side tape about 1" wide...not sure where it used thanks.
PS...anyone in NY/NJ/CT that has installed this in Intake in an AC ITR wanna help with the install???
Thanks
Modified by Trellis at 5:15 PM 4/11/2006
Old Apr 11, 2006 | 01:22 PM
Trellis's Avatar
Default Re: Mugen Intake Directions Translated (Trellis)
Nevermind I found it....wish it was bigger though.
https://honda-tech.com/zerothread?id=868821
But if anyone is interested in meeting up to help with the install let me know...I'll buy and Pizza
Old Apr 11, 2006 | 01:52 PM
Raabjorn's Avatar
I installed a mugen intake on my ITR with AC. And it was no problem.
It took a long time to get in place, but the AC wasn't the bigest problem!
It's just very narrow, so you have to push and turn it around to get it in place.
Just bend the ac-lines a bit to each side and put strips on them to hold them
You also have to loosen the radiator and other things. Once I found out I should loosen the radiator, it was much easier!
Good luck!
Old Apr 11, 2006 | 04:19 PM
Haleiwa-Brando's Avatar
Default Re: Mugen Intake Directions Translated (Raabjorn)
If that is too hard to read on that instructions link, the smaller tape is supposed to go on the venturi piece that slides into the larger piece. The metalic tape is to then go around that seam to cut off any air leak. That big black plate with the bend in it... I didn't get that with mine. I got this bracket that slips around where the two pieces meet, it tightens down then the other side of it bolts into a factory 10mm hole on the radiator support.
Old Apr 11, 2006 | 05:36 PM
Padawan's Avatar
Darth ModerVader
I've never performed the installation, but I'd still be happy to lend a hand if you'd like.
Old Apr 11, 2006 | 07:10 PM
Trellis's Avatar
Default Re: Mugen Intake Directions Translated (Padawan)
thanks...Does the air filter need to be oil'd?
Old Apr 11, 2006 | 08:52 PM
Takumi Fujiwara's Avatar
you ****! I'm jealous.
Old Apr 11, 2006 | 09:55 PM
B2FiNiTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trellis &raquo;</TD></TR><TR><TD CLASS="quote">thanks...Does the air filter need to be oil'd?</TD></TR></TABLE>
nope
Old Apr 12, 2006 | 03:50 AM
Trellis's Avatar
Default Re: Mugen Intake Directions Translated (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">
nope</TD></TR></TABLE>
Kool! Thanks Can't wait to install it.
Old Apr 12, 2006 | 04:29 AM
Lucky-R's Avatar
sweet intake...i need it in my life, and have needed it for a looong time now. hope i can get it soon before mugen discontinues the damn thing like a lot of their other good stuff
Old Apr 12, 2006 | 07:54 PM
ITR#132's Avatar
It comes pre-oiled, but YES. Theres also a cleaning/oil kit for it.
Old Apr 12, 2006 | 11:47 PM
ildknyli's Avatar
Default Re: Mugen Intake Directions Translated (ITR#132)
Id pick one up if I didn't need ot mod the AC line.
Old Apr 13, 2006 | 03:59 AM
Trellis's Avatar
Default Re: Mugen Intake Directions Translated (ildknyli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ildknyli &raquo;</TD></TR><TR><TD CLASS="quote">Id pick one up if I didn't need ot mod the AC line.</TD></TR></TABLE>
as the other writes states...spreading the AC lines out of the way was no big deal...the hardest part was stuffing that BIH down
kkim
Nov 18, 2019 11:14 PM
HondacivicSI09
Honda Civic (2006 - 2015)
Jun 21, 2009 02:13 PM
typesgsr
Apr 17, 2008 04:07 PM
ITR-2001
Aug 22, 2005 01:32 AM
