someone tried to steal my hatch and jacked up the ignition - are there any honda junkyards in so.caL
i guess they tried to steal it with a screw driver because a big chunk of metal is stuck in the ignition hole. they also broke the driver's side key hole so i get into my car through the passenger side. for some reason, they couldn't finish the job, so they just stole everything inside my car. i'm gonna miss my cd's the most - i had over 100 albums in my cd book.
anyways, anyone know a junk yard in so.caLi that might have the ignition parts? do you guys know which parts i have to buy to fix it?
Modified by smooz EK at 10:40 PM 4/11/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smooz EK »</TD></TR><TR><TD CLASS="quote">anyways, anyone know a junk yard in so.caLi that might have the ignition parts? do you guys know which parts i have to buy to fix it? </TD></TR></TABLE>
I normally suggest replacing it with new but if you want junkyard parts there are tons in so cali.
for 1995 Honda Civic Si:
honda oem pn: 35010-SR3-A01 LOCK SET
question is, are you talking so cali la or the so cali sd ?
in SD:
HAP (Honda Acura Parts)
Ecology
Import Auto Wrecking
Pick your Parts
and tons more on the streets of the mentioned locations...
in SD:
Ecology
Pick your Parts
Imports Auto Wreking got everything
and Asia Kars.. that's the one's i know
it's off 805 South then Main Street exit and then left the light and a few blocks down .. make a left go up and then right on the stop sign.. then up the hill.. before you go up the hill the imports auto wrecking is to the left first shop.. and asian kars is all the way to the top.
well..i called honda for a new part, and its only about $120, so im just gonna get it new like del sol sugested then. the labor rate is outrageous, so i was gonna try and do it on my own. has anyone ever done this or know how to do it?
it's very straight forward, very easy to do. just start taking things apart around it. your ignition assembly will have leads to 2 leads of wire plugs brown in color unplug them and take off the ignition assembly that are held on by 2 srews at the top you'll see what i'm talking about when the cover is off you can pm me if you need help, kinda hard to explain i guess
what were the odds of someone asking the same question only days apart...
https://honda-tech.com/zerothread?id=1588875
there are 2 pick your parts in Wilmington - 710 and pch I think. One of them is huge and always has hondas. If you go there you wont have to pay a jacked up price like as if you were going to HAP or Import Auto Salvage.
speedswing
Apr 5, 2007 12:34 AM
ComCool
12
Mar 22, 2005 09:15 AM
