miller 180SD or the 200SD
Heys guys im looking for a tig, i have really never tig'd so i'd like to start. I have mig welded. But im looking into doing alumium. It will be mostly for garage use. I dont want to spend too much i just need a pretty good aluminum and stainless welder
hmm on the cornwell truck he said he has a 180SD and can't get a 200SD
I went to local welding supply and they had a 200SD for 1940 with the runner package
Go with the syncro200, its just a little more. Unless you can find a 180SD for cheap.
Check for http://www.airgas.com They have reasonable prices actually, compared to 4-5 welding suppies stores around my area. They are a nation wide company, if you want it locally. I had good experience with them, other dont.
Most can match any online prices to, only that uncle sams a b!tCh.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weiRtech »</TD></TR><TR><TD CLASS="quote">you can run a watercooled torch on it i believe.</TD></TR></TABLE>
FYI. it doesnt come with a watercooler.
any tig welder can run a watercooled torch with the proper equipment
I have the 180SD, bought it used from a member here and I'm very happy with it. I have only used it for aluminum so far and it seems to be just fine for that. I too just wanted a cheap(ish) welder to use in the garage for intake manifolds, IC pipes, brackets and later some stainless/mild steel exhaust manifolds.
Fred
Fred
we had a 180 for about 8 months. once the 200 was released we immediately upgraded to that unit. im hoping to purchase a 350 in the near future once i gather the funds and keep the 200 for low amperage duty.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quickgti1.8t »</TD></TR><TR><TD CLASS="quote">hmm on the cornwell truck he said he has a 180SD and can't get a 200SD
I went to local welding supply and they had a 200SD for 1940 with the runner package</TD></TR></TABLE>
Because he wants to sell the "outdated" 180
I went to local welding supply and they had a 200SD for 1940 with the runner package</TD></TR></TABLE>Because he wants to sell the "outdated" 180
YZFR6
Welding / Fabrication
11
Nov 26, 2009 05:13 PM
locash
Aug 2, 2007 05:41 PM
