d16 from an Si into an HF
Old Apr 11, 2006 | 09:50 AM
wood 1's Avatar
Default d16 from an Si into an HF
I have a wrecked CRX Si and need to put the motor into aCRX HF with d15. Can I pull the engine, harness, and ECU and just hook everything up, or are there other modifications needed? I found a lot of info on d16 heads on d15s but didn't see anything on a complete swap over. It's hard to search Si and HF. I'm sure this has been covered but I couldn't find thhe answer. Please steer me in the right direction. Ireally need to know this to get a friend back on the road!
If you can't help, please bump, I only have 2 more posts- being a noob you know!
Modified by wood 1 at 12:02 PM 4/11/2006
Old Apr 11, 2006 | 01:18 PM
wood 1's Avatar
Default Re: d16 from an Si into an HF (wood 1)
BUMP! anybody? I could use some help! Come on, someone must have answer, where are all the pros whenyou need them? Also what would be a fair price to have this done? We are talking CRX by the way.
Modified by wood 1 at 2:40 PM 4/11/2006
Old Apr 11, 2006 | 02:14 PM
dr_latino999's Avatar
STEPS
Remove old motor
Put in new motor
THE END
The HF wiring harness has all the provisions needed for a D16A6 since the chassis is already wired for MPFI. On the inside, just remove the stock computer and plug in the PM6 and that's all that needs to be done. If you are retaining your stock hubs, you do not need to change the axles.
Old Apr 11, 2006 | 02:17 PM
4cefedcrx's Avatar
i have a 88 hf with a d15 in it. but i need a hf wire harness, if anyone has one they wanna get rid of
Old Apr 11, 2006 | 06:20 PM
wood 1's Avatar
Default Re: d16 from an Si into an HF (dr_latino999)
Thank you for your response, hopefully I will be able to help you in the future
Dan
Old Apr 11, 2006 | 07:18 PM
mr_hahn73's Avatar
direct swap into the hf.
EK FLY
Oct 8, 2005 07:36 AM
fullraceacura
May 24, 2005 09:49 AM
tcwcrxhf
Jun 27, 2004 04:42 PM
JSPECHB
Jul 16, 2003 07:31 AM
91HATCH
23
Oct 15, 2002 05:03 PM
