Steering issue
Old Apr 11, 2006 | 08:27 AM
PogiDC5's Avatar
Default Steering issue
I lowered my dc5 about 3 days ago with ground control coilovers, they are a perfect ride. but the only problem is my steering is all messed up, i took it to get it aligned and it didn't seem to fix the problem. its weird. if i make a left turn the steering wheel will sit off centered and if i center the wheel the car will drift to the right, so i have to hold it slighty to the left, but when i turn back to the right it will return back to center... but most of the time its drifing to the right even after i make a right turn ? i had them double check my alignment to make sure it wasn't off again and everything is good? n e idea what the problem might be? ?
Modified by PogiDC5 at 1:45 PM 4/11/2006
Old Apr 11, 2006 | 11:57 AM
BoBoChan's Avatar
Default Re: Steering issue (PogiDC5)
iis your car lowered? i think it has something to do with the camber
mine is lowered on some random springs from the previous owner and it has the same problem with drifting to the right.
Old Apr 11, 2006 | 03:36 PM
J_Bones's Avatar
Default Re: Steering issue (BoBoChan)
your toe is off.
duyfash0
Jan 8, 2008 04:44 AM
Playa_FL
Mar 10, 2006 07:54 AM
vtec_crazy
Feb 16, 2005 01:51 PM
Darren S
Acura TL, RL & ZDX
Jun 29, 2002 05:08 PM
