Check out these pics: Std. vs. SOHC ZC wiring...
Ok, the cyl. pos sensor wires and plug hook up no problem, as seen in this pic:
However, the other two dizzy plugs do NOT meet. as seen on the bottom, the plug on the left only has 5 wires, and the plug on the right has seven wires. I'm not concerned about the plugs matching, cause i can just solder the wires directly together, but how do i get the wires to match? and where do the other wires come from?
the easy and most common way is to get the other side that plugs into the 7 wire distributor plug and just cut the old 5 wire one off and match color to color, then run 2 new wires from the ecu (most DPFI to MPFI write ups have the correct pin outs and wire colors) to the new 7 wire distributor plug (green, and blue if i remember correctly)
but yeah other wise just de-pin or cut the wires and match them color to color, then run 2 wires from the ecu and wire them to the 2 extra on the new distributor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohdoh420 »</TD></TR><TR><TD CLASS="quote">then run 2 wires from the ecu and wire them to the 2 extra on the new distributor </TD></TR></TABLE>
I got that bit done already. It was cake.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohdoh420 »</TD></TR><TR><TD CLASS="quote">but yeah other wise just de-pin or cut the wires and match them color to color</TD></TR></TABLE>
But about this, none of the colors match!!! I got five wires from my harness, and five wires on the dizzy, but no colors match! Anyone got a diagram or sumthing?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi »</TD></TR><TR><TD CLASS="quote">the 2 pin plug in the 1st pic is the dizzy power and tach wires... The cyl pos wires are blue/green and blue/yel in the 8pin plug</TD></TR></TABLE>
o, ok, cool.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bserieskllr »</TD></TR><TR><TD CLASS="quote">did your sohc zc come with the dist. plugs????? if so the colors you need tomach are on the other plug if u dont have it let me know.</TD></TR></TABLE>
I figured it out. All the colors match except for whever there is "peach". instead of peach on the usdm plug, they use orange. the stripe is still, blue, but peaqch turned to orange.
I'm gonna pick up some quick disconnects from radioshack tonight and wire them up so they aren't permanent. wish me luck!
o, ok, cool.
lsvtechatchy
May 13, 2010 09:26 AM
