tach problem
Old Apr 11, 2006 | 06:32 AM
Performance Freaks EH's Avatar
Default tach problem
the tach in my 91 dx is actin weird. when i give it gas the needle pegs down to zero and when im not on the gas its bounces around and doin what it ever it wants. any help with this?
Old Apr 11, 2006 | 07:22 AM
MEBHB91's Avatar
Default Re: tach problem (Performance Freaks EG)
if its an after market tach pull it out and check you wiring but if its an si cluster do the same thing, you might have wires crossed or something simple like that
Old Apr 11, 2006 | 07:24 AM
its all factory but im def gonna check the wiring again
Old Apr 11, 2006 | 07:31 AM
Jstuneshop's Avatar
somtimes this problem occurs when you have a bunk *** distibutor, try a different one to see if it solves the problem.
Old Apr 11, 2006 | 07:32 AM
jdm91CrxSi's Avatar
Default Re: (Jstuneshop)
go to the dizzy and cut the plastic a little or make sure the green wire to/from dizzy isn't cut
Old Apr 14, 2006 | 12:15 PM
hondacrx92's Avatar
I have a similar problem with my del sol, its the standard cluster. I have just replaced my distributor as well, so it cant be that. But when im driving my tach jumps all over the place, but when idling its fine.
g0tuj0ckin
Sep 25, 2008 08:01 PM
Nataku
Dec 3, 2005 07:12 PM
Mantis88ls
May 23, 2004 09:13 PM
DCx2xNV
Mar 4, 2002 10:45 AM
