a ZC question
i just bought an obd1 zc engine, will it fit my car?! i just bought the cylinder head and and valves cover and everything under it, will it work with my sohc ZC intake and headers?! what about the distributer?!
thanks HT
thanks HT
i have 88 crx obd0 sohc ZC, i want to put a dohc ZC i just bought but its obd1 engin, i only bought the cylender head and valveves cover and evrything inside it, i'll use it with my stock intake and headers, will it fit?
did you get complete engine or just the head? you can't easily put the DOHC head on the SOHC engine, if that is what you are trying to do - SOHC intake manifold will not fit DOHC ZC head - header will bolt up but ports don't line up exact - you need to grind out the header to match the ports in the head - fairly easy job
let me try again - did you get the complete block with head and valve cover? just missing intake manifold and header? to bolt the OBD1 block into your car, you would need to swap the mount on the driver's side end of the block from your SOHC onto the DOHC - rest of mounts are on the transmission - you would need DOHC ZC intake manifold - use the SOHC injectors - you would need 88-89 Integra distributor and CYL position sensor
ok thanks, i swapped and obd1 d15b vtec a year ago and used the same intake and headers, so i thought they r the same with the obd1 dohc ZC, cuz the ZC i got said D16A a D series, i thought all D series are the same withe headers and intake, and answering ur question yes i bought the complete block with head and valve cover, i'm still using my obd0 intake from the old sohc zc and PM6 ecu and the sohc ZC distributer and they all work finr with d15b vtec obd1
zc is it's own code it's not a D series the Itake Manifold Will Not Fit, As he said and also the headers will, yes it will mount up and yes you can't put a dohc zc head on a sohc block
but i bought the whole block and the engine said d16a not zc, i wont use any sohc block or engine part, i can buy the intake and headers too, but if i did, will the intake work with my OBD0 wiring?!
dont waste your money on that head w/o the bottom end or a d16a8?? i think thats the code its from an 88-89 integra comonly called the "brown top"
the dohc zc head will not fit the sohc block
the d15b is basicaly a d15b7 bottom end with a z6 head with the pistons and cam being a little different from the d15b7 and d16z6
just keep this in mind
anything from a d series will fit on a d series
anything (almost everything) from a b series will not fit on a d series but will fit on any B coded block
Therefor i just supplied you with a full 20 weeks in college
ok i know that thanks, but the engine i got d16a is written on it. NOT ZC, so it will fit right? cuz the d15b vtec worked on my sohc ZC intake and headers!1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si0385. »</TD></TR><TR><TD CLASS="quote">
the d15b is basicaly a d15b7 bottom end with a z6 head with the pistons and cam being a little different from the d15b7 and d16z6</TD></TR></TABLE>
Actually a d15b single stage vtec is really a d15z1 block with a D16z6 head and slightly better camshaft..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zenon8890 »</TD></TR><TR><TD CLASS="quote">anything from a d series will fit on a d series
ok i know that thanks, but the engine i got d16a is written on it. NOT ZC, so it will fit right? cuz the d15b vtec worked on my sohc ZC intake and headers!1</TD></TR></TABLE>
Im not really understanding your question at all... in the first post you say you have a obd1 zc now you say you have a D16a that you're swapping inplace of the current engine which is a D15b vtec..If the new engine is not a ZC then it may not fit ..Whats the whole engine code..?
but its a dohc 1.6 liter engine, i'll take a picture and send it to u guys, so if it is zc it wont fit my intake and headers, the headers have the same pattern of the zc
