No Signal From ECU!
Old Apr 11, 2006 | 04:51 AM
xvietxkhmerxboix's Avatar
Default No Signal From ECU!
Okay here the problem my CEL came on so I go and plug my OBD2 reader/scanner up and it telling me its not getting a signal from the ecu. So I'm thinking maybe a wire or wires isn't hooked up correctly. The car is a 99 Civic Hatch Dx OBD2b when I first swapped in a 01 b18b motor using the 01 b18b OBD2B ecu I had to switch around a few pin outs on the ecu harness for the car to run correctly.
Everything worked fine if I threw a code my reader/scanner would tell me what code I'm throwing. Now I have a b18c using a 96 gsr ecu OBD2a I had to buy a conversion harness to run that ecu. Well now it seems like my reader/scanner won't get a signal from the ecu. So What I'm trying to figure out now is what wire do I need to switch back or hook up to get signal from the ecu?
Old Apr 11, 2006 | 12:20 PM
Default Re: No Signal From ECU! (xvietxkhmerxboix)
bump1
Old Apr 12, 2006 | 04:30 AM
bump2
rizzuto
14
May 17, 2013 07:59 PM
lazii_boi08
Oct 22, 2008 09:16 AM
2khb
Aug 2, 2004 05:45 PM
Eclpze97
Jun 22, 2004 06:33 AM
