91 accord ex CD PLAYER LOCKED!!! NEED HELP!!!
Old Apr 10, 2006 | 08:54 PM
94CIV's Avatar
Default 91 accord ex CD PLAYER LOCKED!!! NEED HELP!!!
just as it says, i have the code but it doesnt want to work. It is the correct code. is there something im missing?
Old Apr 10, 2006 | 09:30 PM
HONCORD's Avatar
Default Re: 91 accord ex CD PLAYER LOCKED!!! NEED HELP!!! (94CIV)
Might have a wrong code. Tell you what. Take your stereo unit out. Call the dealer, tell him whats going on and give them the stereo number. They keep all the info and will help you out for no charge. If its already locked, (which usually happens after maybe 3-4 tries) disconnect the radio from the harness, it will reset the anti-theft system (I think disconnecting the battery might work too). Then try your code again.
Old Apr 11, 2006 | 08:04 AM
94CIV's Avatar
Default Re: 91 accord ex CD PLAYER LOCKED!!! NEED HELP!!! (HONCORD)
If it were locked would it say it was? Right now it flashes CODE. And i have had this problem before, and so i wrote the code inside the fuse box cover. I know i have that right, it just doesnt want to work.
Old Apr 11, 2006 | 12:37 PM
Ross 2.0's Avatar
In a Junkyard near you.
You don't have the right code. Do you have the sticker inside of the fusebox with a series of letters and numbers or 6 numbers?
If it's not accepting the code and your 110% sure it's the right code then the audio unit has gone bad.
ShankJDM
10
Jan 9, 2008 10:21 PM
utmanzai
Mar 19, 2007 06:51 AM
cannan
Nov 11, 2004 08:32 AM
Crono139
Jul 17, 2003 01:24 PM
