Recommended tire pressure for a 16x7 wheel on 205-40-16 tires?
Old Apr 10, 2006 | 08:17 PM
$amGD3's Avatar
Swaggylicious
Default Recommended tire pressure for a 16x7 wheel on 205-40-16 tires?
What's a good tire pressure for me in this situation?i dont want super traction,i just want comfort..some people say go with oem specs which is around 33psi all around,right now i'm running 34psi in the front and 38psi in the back..is this ok?or what should i change it to?
Old Apr 10, 2006 | 08:50 PM
DoctorGSR's Avatar
whatever it says on your door jamb.
Old Apr 10, 2006 | 09:16 PM
JDMTurboEG6's Avatar
Default Re: Recommended tire pressure for a 16x7 wheel on 205-40-16 tires? (sam21)
i used to work at firestone and we used to recommend that any low profile performance tire be set to 40psi but depending on what you use your car for then you might want to experiment with different air pressures because with the 40 psi car rides kind of harsh you feel every little bump on the road but it also corners great too so it depends what your comfortable with
Old Apr 10, 2006 | 09:40 PM
nsxtasy's Avatar
H-T Order of Merit
Start with what your owners manual says (which is also what's on the door jamb, as the good doctor noted).
Old Apr 11, 2006 | 10:58 AM
DoctorGSR's Avatar
Default Re: Recommended tire pressure for a 16x7 wheel on 205-40-16 tires? (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
dubnine
Sep 2, 2008 08:11 PM
RACEPAK
Jul 12, 2008 04:27 PM
Floored
Apr 20, 2005 06:57 AM
TealCivic93
Feb 19, 2005 05:04 AM
First Honda 1976
Jun 8, 2004 07:08 AM
