k20A
Old Apr 10, 2006 | 08:09 PM
AnR5I0's Avatar
Default k20A
just wondering is the rsx type S is stealible..? is the ecu the same as the dc2 obd2?
Old Apr 10, 2006 | 08:29 PM
entityzero's Avatar
Default Re: k20A (AnR5I0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnR5I0 &raquo;</TD></TR><TR><TD CLASS="quote">just wondering is the rsx type S is stealible..? is the ecu the same as the dc2 obd2? </TD></TR></TABLE>
BAN!!! This is a technical question that really shouldn't be asked.
Old Apr 10, 2006 | 08:42 PM
ZipTieGUy's Avatar
well you need a RSX ECU and the KEY for that ecu. i dont know much after that
Old Apr 10, 2006 | 08:51 PM
dem0nk1d's Avatar
Default Re: (ZipTieGuy)
The ecu and the ign, plus the key. Relay a code back and forth to each other. So something like this... Key has a code programmed in it, like lets say 12345. Which sends to the ign modual and retrives 12345 and says okay or no if it's a match. Then from their it sends it to the ECU if the code matches then your set. Also I know that has-sport does a reprogram on the ecu's that disable the code lock. And i belive the JDM car's do not use the technology. So thus if you had a JDM ecu. It wouldn't check for a code... It's not like the old technology. Where you can unscrew the back of the ign, and pull the ign switch out and turn the car.
Old Apr 10, 2006 | 09:20 PM
Bense's Avatar
Default Re: (dem0nk1d)
mmmm boogers!!! P-:
Old Apr 10, 2006 | 09:23 PM
Turbo_y8's Avatar
i knwo where to point guys when i read the next stolen rsx type s thread
Old Apr 11, 2006 | 12:09 PM
dem0nk1d's Avatar
Default Re: k20A (tuck'd98)
Muhahaha, i am just trying to enligten the poor guy. Knowing is half the battle....
dem0nk1d's Avatar
Default Re: k20A (dem0nk1d)
Plus f**k all the bullsh!t, people now adays are stilling cars via tow truck.
Old Apr 11, 2006 | 12:13 PM
96accordlxf22b2's Avatar
I cursed out BauleyCivic and got banned
it would be alot easier to steal the car then rip out the parts needed, dont sit there in a parking lot bolting on ur own jdm ecu, take the car grab everything then sort out what u dont need and do need..........................im not trying to help u its just that theives are really ******* stupid
some say if they were smart they wouldnt be criminals maybe this will set u on the right path
Old Apr 11, 2006 | 12:14 PM
MrSparky's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d &raquo;</TD></TR><TR><TD CLASS="quote">Plus f**k all the bullsh!t, people now adays are stilling cars via tow truck.</TD></TR></TABLE>
hahahah yea true. especially gettin those flashy aftermarket tow hooks! heh jk.
Old Apr 11, 2006 | 12:17 PM
Default Re: k20A (96accordlxf22b2)
or maybe not
to answer the question ya u need the key basically but i read the thread posts abouve me so i wont get into detail...................why would u want to steal one anyway? u going to take from someone that earned there motor rightfully? why dont you get a job save up a few thousand and buy one itll be cheaper in the long run
u have vins on motors these days, (grind that sombitch off), ur really not going to pass smog(if u try to get it smoged they see the vin number is grinded) u cant make a fake vin number, u dont have a title to tthe motor, i mean goddamn kid give it up
Old Apr 11, 2006 | 12:18 PM
kidkombo's Avatar
nothing is 'unjackable'..if people want it, theyll take it by all means necessary...but you all knew that already
Old Apr 11, 2006 | 12:24 PM
dem0nk1d's Avatar
Default Re: k20A (kidkombo)
back in the days when i use to goto the street races. i've seen people turn a 3 into an 8 , on the engine serial/vin number clever ****... but still yeah jacking is no, good but it's good to know how to protect your self by block all backdoors possible. but the tow trucks are the key for the cars now adays.
Old Apr 11, 2006 | 12:27 PM
ya thats pretty clever but still if u chnage all the numbers........its still fake right?
they run it nothing shows up, then they see all the stolen numbers, bam something simalar pops up they examine it then they find the number, jail
mrDFWmechanic
10
Oct 1, 2009 04:19 PM
chessboxer
12
Jun 24, 2009 06:58 AM
thielke2004
Sep 9, 2005 07:00 PM
JoeyBallzSI
May 2, 2004 07:50 PM
